I have the LG Washer Tromm- and they said the water drain pump needed to be replaced. they charged me $50 to come out and look and another $250 to replaced the drain pump. Is $300 excessive?
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
Motor will cost you $75, and about an hour to replace it. Check out YouTube, plenty of videos on how to do it. Did it yesterday,nothing difficult.
I just had mine replaced this morning $328.00 and 1 yr guarantee...I felt ripped off at first but I'm over it:)
I think I might need a new drain pump too. Was drain water backing up into the drum when empty?
I had the same issue ant the pump is about $50 and $75 to replace.
I HAD THE SAME PROBLEM, I HAD THE DRAIN PUMP REPLACE AND 6 MONTHS LATER THE SAME PROBLEMS SEARS IS THE ONE REPAIRED.
Water will not drain during cycle
