Does the tub on this model run on a belt or does it set on bearings?
What model is it? The answer is probably both. Every machine I've worked on has a motor with a belt that drives a pulley that turns the tub held in place by bearings. Your squeal could certainly be caused by a bad belt. If the belt looks bad change it. If it looks okay, try a squirt of belt dressing, if the squeal disappears change the belt. If it is a front loader open the loading door, put one hand just inside the tub at the top (like a waiter carring a tray shoulder high with one hand) and LIGHTLY push upwards then drop your hand a little then push upwards etc., etc. If the whole tub moves solidly you are okay, but if you feel a wiggle or a slight space in the jump (man this is harder to explain than i thought it would be) then your bearings may need attention. I doubt it is your bearings causing the squeal though. Does it squeal through entire spin cycle, or just at the beginning?
SOURCE: Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal
belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
SOURCE: Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
SOURCE: My washer squeals during spin cycle model
The belt on my was the culpret. The washer belt has a spring loaded idler. Unplug power and move the idler off of the belt and use a spring hook or longnose vice grips to pull spring out of slot and into the next slot closser to you. There are 5 slotts. Push idler back by hand and put belt back on it. Your done. The transmission just spins as a unit in spin cycle, it does sit on top of a bearing,but that didn't seem to be the problem. If the belt tension doesn't fix it, put some grease and oil in the bearing or replace it.
Eventually you will need a new belt so order one now.
