SOURCE: can i download kindle to
You need AppsLib on your tablet (you can download from them), and from there you can search for third party readers (I dont think you can get kindle as its designed for phones). Android tablets dont have access to the android market place therefore tablet manufacters have their own - in this case AppsLib.
SOURCE: my coby kyros internet tablet wont turn on
i cannot turn on my coby kyros internet tablet after charging and there are no answers or problem tips in user manual
SOURCE: I purchased the coby kyros internet tablet from
Hi! As a first course of action, I strongly suggest that you look via internet for the driver. Hope this helps and thank you for using FixYa!
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase
Everything"
The following will occur:
• The screen will display COBY
• The screen will display Android
• The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target.
Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home".
The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until:
1- You have configured your Wi-Fi
2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
SOURCE: where can i find free driver software download for
Need
driver and bios updates? Always
get your drivers and specific software from the manufacturer of your
Laptop, Notebook or Desktop. They are usually free of charge. If you were to log on to the
manufacturer's
web
site,
usually one is able to download if available, by model
number,
All
available Driver
downloads
as required.
If the driver is not
available, perhaps your manufacturer does not support the OS you are
installing. This is the best way of ensuring up to
date drivers for your system and they are free of charge! I hope this helps.
