Toymax Viore  42 in. Plasma TV Logo
Steven Kempel Posted on Dec 31, 2012
Viore 42 inch plasma tv speakers crackle - what causes that?
Speakers crackle on some shows -happens off & on.
5 Related Answers
Anonymous
  • 1284 Answers
  • Posted on Oct 17, 2009
SOURCE: remote code
Contact them here:
Parts & Accessories
(remotes, cords, manuals, service parts etc.)
[email protected]
Rinoo Kumari
  • 2973 Answers
  • Posted on Nov 07, 2009
SOURCE: my viore 42 in plasma is not projecting image. I
The video IC module seems to be giving problems. Open the back cover and take a peep inside. Look for the module just short of the screen. replace it if need be.
Anonymous
  • 124 Answers
  • Posted on Jun 12, 2010
SOURCE: my hdmi connection wont stay on on my vior plasma 42 inch
You may have used Monster cables which can expand the plug in the TV.
Sorry, but you'll need to get a new input or use tape to hold it in.
Anonymous
  • Posted on Feb 02, 2011
SOURCE: Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
UberTechzor
Daniel
  • 299 Answers
  • Posted on Sep 11, 2011
SOURCE: i have a viore 42
Hello kdmuszik,
Welcome, and thank you for using FixYa!
Your issue is with your Tuner Board. This piece will have to be replaced. All commands for picture ratio, color, and size transmit to the TV through this board. I have inclusded a link to the board you should be looking for, below.
Tuner Board
http://www.ecrater.com/p/10863238/viore-tuner-board-311229714221j
Have a great day!
Viore 42" plasma has picture but no sound
check first at the sound set up menu might set to off. if the settings is ok and the speaker is also good, the cause is either bad amplifier circuit or sound processor at the main board. at this time you will need a trouble shooting.
1helpful
2answers
Viore 42 inch tv PD42Vh80 had no sound but great picture HDTV
speakers switched off?
volume on set or a box down or muted? check both the set and box.
Does the set have normal sound when playing a DVD etc via the audio and video jacks on the rear or side?
Tv repair for vior 42 inch something wrong w the screen the and not clear but the voice and rest is working picture very grainy poor focus
a dull picture is usualy caused by the z-sustain board but i have known the y-sustain give the same symptom sorry cant be any more help these boards can run quite expensive try getting used ones from ebay i would go for the z-sus first
2answers
Hi , was watching my 42 inch VIORE Plasma TV last night, when I heard a click noise and the picture went immediately but the sound remained fine, I could switch channels but no picture, would you have any...
Check high voltage circuit. This is near where the 120 volt cord is plugged in and a high voltage transformer, where there should be capacitor (or two). Check the voltage - should be 390 to 400 volts. If not less than 390, near to replace the capacitor.
18helpful
1helpful
2answers
Viore tv sound but no picture
the sound suddenly stopped working on my Viore 42" plasma.
My hdmi connection wont stay on on my vior plasma 42 inch
Remote code
Contact them here:
Parts & Accessories
[email protected]
1helpful
Viore 42 inch plasma tv--wont power on--light shows yellow
Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
44helpful
4answers
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Top Toymax Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
