It sounds like the pull-out switch, under the pull-out knob, is not working and may need replaced. Go to Repairclinic.com and type in what your washing macine is not doing and they will give you hints on what to do next. But, it sounds to me like that is what is wrong with your washing macine.
Hi and welcome to FixYa, I am Kelly.
The humming noise your hearing is the inlet water valve solenoid. Before proceeding try switching between warm cold and hot to see if any of those selections give you water. If you get water on either hot or cold then you probably have debris in the inlet screens of the water valve where the hoses connect. Turn off the water. remove BOTH hoses noting hot and cold installed positions and the use a thin knife blade on the outer edge of the screens to lift the inlet screens out of the water valve body. Wash then under slowly running water rubbing them between your fingers. Reinstall the screens. Connect the hoses in their original positions, turn on the water and test your water fill again switching between warm, hot and cold. This should get you going. If your still having problems after doing the above; please respond with MODEL: number and I will help you.
Thanks for choosing FixYa,
Kelly
Hi, if there's no water at all, make these checks:
Is there water getting to the machine?
Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Is there water getting to the machine?Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.Replace the "water inlet valve" with this part.
If there's no water at all, make these checks:Is there water getting to the machine?Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
There's no water at allIf there's no water at all, make these checks:Is there water getting to the machine?Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Check your water level switch it may be showing full. If it is it won't fill. If you can set it on spin and run for 2 or 3 min. it might clear the hose from the tub to the switch in case there is too much water in it. Or you could pull the hose off the switch and blow in it to be sure it is clear. Sometime if it gets too much in it it builds up too much pressure and shows full.
check the setting of the water temp for the rinse cycle. If one of your water supply valves is closed (HOT/COLD) the tub cannot fill with the proper water temp selected. The hum noise you are reporting is associated with the fill solenoid valve located in back of the machine.
Also, I have found the problem to be the screen located in the fill valve clogged with rust and water deposites. Disconnect both water lines and verify the water supply is not restricted.
Hope this helps..
If not, a more thural description of the problem may reveal more clues to assist in troubleshooting.
Thanks and good luck...
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it. Good luck!
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
