Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Washing machine won't spin
Hi I have a hotpoint wt965 washing machine and the drum won't spin at all, the water fills up ok and drains ok but the drum won't turn. I've tried a normal spin and also to try another wash. The digital timer counts down normal and that's all......please can anyone help???
  • 85 Answers
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Posted on Jan 18, 2009
6ya staff
SOURCE:
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
Hotpoint WT965 is making a loud noise when spinnig
Suspect bearings. With door open wiggle the top of the silver drum If it moves up and down inside the tub, replace the bearings
May 15, 2012 | Washing Machines
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Jun 25, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
553 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
