MTX 502 bridged into 2 ohm load. Power system up seems a little weaker than normal. Unhook left rca wire...no change in output. Plug left rca back in unhook right.. silence turn gains up no help... replaced rca wires...no help. Looked carefully over circut board for anything unuasual with no results. Also the left rca output is dead. Assumeing this is a simple problem early in the amplifieing process. Any help with maybe a scematics diagram??
Unless your amp is 1 (one) ohm stable then you may have fried it. When you attach a 2 ohm load across a bridged amp then you have effectivly placed each output channel on a 1 ohm load. Not a good thing in most cases. Try hooking up ONE speaker on one channel and one input to that one channel one at a time. Then switch the speaker/input to the other channel and see if you can get either or both channels to work independently. Needless to say you must turn the amp off before you make ANY change in the wiring.
MTX Powers On And Plays For A Bit Then Powers Off Then Sometime Power Right Back On Or Sometime it takes awhile to power back up and is not hot and never gets hot But power is right from battery and ground to frame I Need Help Ple
