Have new motor but cannot seperate the fan from the old motor. how do you remove the fan from the motor?
If you have (visegrips) use one on the shaft, and one on the fan shaft, use a little penetrating oil on the shaft, move both part in opposite directions, this should loosen up the fan from the shaft, it might take a while and sometimes it is not an easy task ! Please do not try to beat the shaft out, as this will mushroom the shaft and you will never get the fan off, another alternative is to buy a new fan blade, hope that helped
Is this the outside fan that sits beside the compressor or the one inside the freezer?
