Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
SOURCE: I have an electrolux washing
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
The motor is toasted...
Problems with a washing machine not spinning or not draining are often inter
related..
If you are having a problem with your top load washer then check out this
tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout
this tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
SOURCE: can you tell me what a code E20 is for an
that is a drain code, you may have a clog in the catch tube,, sorry to tell you this but the tube is inside the hose that comes off the bottom of the drum, , you should be able to take the back cover off and find the black soft rubber hose coming off the bottom of the tub,, take it loose and look down in it , there is a white plastic trap in there to collect things such as coins and socks,, if coins get in there then lint will start to build up and then it slowes the drain down
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
p'';
