Question about Cell Phones
My phone screen will not turn on it stays white, and i'm going to get a new phone but would like to save all my contacts to sim card, everything works, i just can't see what im doing! Please help
  • Cell Phones Master
  • 3,267 Answers
Connect it to a PC, synchronize or copy all contacts, then transfer the same onto your new mobile
Posted on Jan 02, 2013
6ya staff
SOURCE:
Anonymous
  • 10 Answers
SOURCE: SIM Card
Verizon is a cdma network and does not use sim cards you will have to go into the store to get the phone switched (they might charge you $20) or call customer service (1-800-922-0204) or do it online yourself by logging on to the vzw my account website.
Posted on Jan 17, 2008
pt44
SOURCE: Samsung D600E - Moving contacts to SIM
Solved my own problem. It was dead easy - so long as you own a Mac (sorry PC users). Just used a free application called iSync, that comes with all macs (its in the apps folder). Synched all my contacts with the D600 easily.
Then downloaded a free script to sync my new Nokia 6301 with iSync as well. Bingo - all contacts copied. Plus - I can now regularly sync my phone with my address book, which is kept on my mac.
6301 script from here: http://www.james-lloyd.com/scripts/nokia-series-40-isync-plugin/
Posted on Mar 25, 2008
gaggid
Gagandeep Singh
  • 80 Answers
SOURCE: Already have numbers saved to
How Do I Copy Contacts From My SGH-d807 Phone To The SIM Card?
To copy an address book contact to the SIM card follow the steps below:
While in standby mode, press the left soft key for Menu
Select Address Book (8)
Select Contact List (1)
Select the desired contact entry, stored in your phone's memory, using the navigation keys
Press the left soft key for Options
Select View (1)
Select one of the contact phone numbers, using the navigation keys
Select Copy (3)
Select SIM (2)
Press the left soft key to Save the single contact phone number to the SIM card
Note: Each phone number for a contact must be individually saved to the SIM card
PS-Not sure about updating/replacing entries though, which is what you may have been asking about
Posted on Dec 28, 2008
133712ap3
Shane Paris
  • 22 Answers
SOURCE: Location of SIM card in Motorola Razr
Are you guys serious....
Verizon & Alltel (which happened to recently finalize the merge) use CDMA. CDMA does not use SIM cards.
AT&T, T-Mobile, etc. use SIM cards - wheter they are 3G networks, TDMA, etc.
Posted on Jun 24, 2009
Colin Gray
  • 96 Answers
SOURCE: change from nokia n95 to new mobile want to save contacts to sim
You'll probably find they're already on the sim, if not here's how to copy them over.
Open contacts, options, SIM contacts, SIM directory; you should see all contacts that are on your sim. If there's none there, select back which will take you to your contacts; choose options again, scroll to mark/unmark press select then mark all, all contacts should now have a tick beside then. Then options again, copy & lastly to sim directory.
Posted on Aug 24, 2009
How do i transfer numbers over from old phone to xperia u st25i?
It depends on the model/make of the phone you have before, but you have a couple of options.
In your contacts, there should be a setting to back-up your contacts. From here, you'll need to choose to back them up to the device or the sim card. If you back-up to the sim card, it will probably limit the number of contacts you can save.
If the old phone is an Android device, you can select to back your contacts up to your google account, after which point, you can relog into your google account on the new phone and the contacts should automatically be synced with the new device.
If you do restore from a sim card, on the new phone, put the sim card into the phone, then go to your settings, within contacts, and import contacts from sim.
So, from the old phone "Export contacts to sim" and on the new phone "Import contacts from sim."
Oct 06, 2014 | Sony Xperia U ST25I Android OS v2.3...
How do I put phone numbers on the sim card
To copy names and numbers to the
SIM card
1 Select Menu > Contacts.
2 Scroll to New contact and select
Options > Advanced > Copy to SIM.
3 Select an option.
When you copy all contacts from your
phone to the SIM card, all existing SIM
card information is replaced.
To automatically save names and
phone numbers on the SIM card
Options > Advanced > Auto save on
SIM.
3 Select an option.
To save contacts on a memory card
Options > Advanced > Back up to m.
card.
SIM contacts
SIM contacts can contain names and
numbers only. They are saved on the
SIM card.
Sep 02, 2014 | Sony Ericsson T707 Cell Phone
LG Xenon - saving Contacts to sim card?
What you want to do is you click the (on the home screen) in the bottom right corner the square with four dots in it. then you click address book, after that you click Management, the fifth section from the top, then you click one of the four options *copy to SIm *Copy from SIm* Delete from SIm *Delete from phone
Apr 29, 2010 | LG Xenon GR500 Cell Phone
My N95 screen has gone black, everything is still working I just cant see anything. All my numbers are saved to the phone not the SIM, anyone got any idea how I can get them off??
Plug the AV television output cable that should have been included with the box your phone came in.
Now plug the cable into your phone and connect it to your TV.
The cable allows you to use your TV as an external screen and from there on you can save your contacts to your SIM card. You can now see and use your phone but while using your TV as a screen.
Now to copy the contacts from the phone to the SIM card, just go to Contacts > mark the contacts you want to copy to your SIM card and then press Options > then scroll down to Copy and it will allow you to copy to either SIM directory, copy to Mass memory or copy from Mass memory. Just select Copy to SIM memory and there you go !
Hope I have been of assistance to you,
Cheers :)
Feb 14, 2010 | Nokia N95 Cellular Phone
Transfer contacts list
1. From the standby screen (the first screen when you open your phone), go to the menu.
2. Scroll to the address book and press select.
3. Scroll to the address you wish to copy (or any address if you want to copy all of them) and press the menu key.
4. Go down to copy and press select.
5. Select "Entries" to copy just that one entry or "All to SIM" if you want to copy all your addresses to your SIM card, or "All to Phone" if you want to copy them all to your phone.
6. Select Merge or Override. Merge will combine any addresses that are already on your card with the ones you are now copying, Override will replace anything that is already there with the ones you are now copying. Be careful in deciding which you want to do since Override will delete anything previously saved and merge will duplicate any that were already saved and are being saved again.
Aug 16, 2008 | Motorola Mobility RAZR V3
Pics won't assign on my RAZR
Master clear you phone and format the memory card. Before doing that back up all your contacts and other necessary data.
May 25, 2008 | Motorola Mobility RAZR V3
K800i White Screen
reset ur phone to factory settings from the menu: warning save ur phone book to sim card or mem card because it will be erased.
Apr 23, 2008 | Sony Ericsson K800i Cellular Phone
My old LG cell phone (LGCU400) broke and was replaced with a newer model (LGECU515). I put my old sim card in the new phone but I cannot retrieve any of my contacts/info from the sim card. Is there...
Hello!
I went to the AT&T/Cingular store and they tried hooking my broken phone to their system but could not retrieve any #s (they were saved to my phone not my SIM). They told me there was no other way to retrieve the #s and that a computer cable wouldn't work bc their system would've been able to retrieve them. I knew there had to be some way of retrieving them bc I could still turn my phone on- the top 1/2 (screen) had just broken off.
It finally dawned on me to look at my husband's phone (we had the same one), write down the buttons to press & the # of clicks per button on my old phone, in order to blindly go through my entire contacts list and save each one to my SIM card. Approximately every 25 contacts I saved I'd switch the SIM card to my new phone and make sure they were all saving correctly. I'm currently still transferring all 137 contacts- grueling but well worth it. This only works if your old phone will still turn on & function even if you can't see/use the screen.
***Make sure your phone's saving your contacts to your SIM and not your phone- I thought mine was and it was one rude awakening today when I found out otherwise! I hope this helps!
Apr 22, 2008 | Cell Phones
Cracked screen tryin to save all contacts to sim for new phone
if you got the same type of phone, then you have to go to the adress book, click options and go to the 13th option. it should be a copy to SIM card option. click it, then go to multiple or selectd, whichever you want. it should copy. PS the # for the copy to SIM option is jst what i have. you might have something different. =)
Apr 07, 2008 | Samsung SYNC SGH-A707 Cellular Phone
SIM Card
Jan 17, 2008 | LG enV VX9900 Cellular Phone
Cell Phones Logo
69 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
