Question about Canon FAX-L350 Plain Paper Laser
Canon FAX L-350 Driver Version 3.11
Where can I download the driver for my Canon FAX-L350 (FAX Suite). My operating system is XP Professional. Thanks jason
  • annosh_yousr Apr 06, 2009
    i have lost the cd of the printer and i need the printer for an urgent thing do you have any way to setup the fax without using the cd
    thanks
  • 318 Answers
Where i can finde driver canon l 350
Hello.
Here is the link. But there is only a driver for Windows 2000 or earlier operating system available.
Choose operating system Windows 2000 (or another) and English and select Submit.
http://software.canon-europe.com/products/0000502.asp
This may not give you what you want, but I hope it solves the problem about use of your L350.
Feb 13, 2010 | Canon FAX-L350 Plain Paper Laser
Pixma MP 160 when I went to install CD I got a pop up that said there was issues With my operating system I have vista
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
You can download the driver from here. Select OS from the drop down menu and than download your driver, depending on the processor you will need either the 64-bit driver or the 32-bit driver.
Sincerely,
Ryan Deschaine
Systems Administrator
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.254.0064
Mobile number: 262.834-5844
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Sep 23, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a canon fax-l350 and I want to use it as printer too. so how can I adjest it with my pc and the required materials and softwares
To set up the L350 as a local printer (I'm assuming that you are not putting it on a network) you will need the Canon FAX-L350 CD-Rom which contains the Fax suite (I have version 3.11). You will also need a parallel printer cable as the fax machine only has a parallel printer port on the rear (the other side to the power cable.
When loading up the CD-Rom (which should have been supplied with your machine - if not you may have to buy one off the web), first make sure you read chapter 2 in the manuals folder on screen then install the driver from the 'program setup.exe' file.
After loading the CD-Rom onto your PC (and before making any physical connections between the PC and the Fax) make sure that the fax is switched off at the mains and also logout and switch off your PC. Next, connect up the cable (Canon recommend a cable that complies with IEEE1284). Centronics supply these cables, but if you do not have a parallel (8 bit ) port on your PC you can get a converter cable (Centronics 36) which will connect the parallel cable to a USB port on the rear of your PC. After checking the connections you can switch your fax back on and also power up your PC. Hope this helps.
Dec 23, 2008 | Canon FAX-L350 Plain Paper Laser
XP installation - CISIF.DLL is not a valid windows image
I DONT HAVE THE SOFTWARE FOR THE DRIVE FAX -L350
SO I NEED THE FREE SOFTWARE FOR THIS DRIVE
AND I WANT TO DOWNLOAD IT NOW
Dec 09, 2008 | Canon FAX-L350 Plain Paper Laser
Driver not found for server 2003
when you do not find the drivers for windows server 2003, try using the drivers for Windows XP.
Most drivers for XP work on windows server 2003
Canon Download page is Official Canon Drivers and Software
Follow istructions, insert model and install drivers.
Start driver setup with scanner USB unplugged.
Sep 26, 2008 | Canon FAX-L350 Plain Paper Laser
Canon FAX-L350 Plain Paper Laser Logo
1,402 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
