Close captioning won't turn off..........on during shows.....doesn't appear during commercials??
Not all TV programs and product
commercials are made with
Closed Caption (CC) information
included. Neither are all Closed
Caption modes (CC1, or CC2) necessarily
being used during the transmission
of a closed caption program.
Refer to your area's TV program listings
for the stations and times of
Closed Caption shows.
To close the close caption display from screen; press "CC" button on the remote control.
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
Different channels and fields display different information, such as additional
languages or supplemental information
I have gone into the settings screen to the close captions options....I pressed # 1 to turn close captions off....no results.....I have powered the TV off after that in hopes it would reset/clear, to no avail. I have gone and tried all options through the settings screen to turn off the close captioning and it still will not turn off?
Do all the other options work except for closed captions when you change them? If so, there is a glitch in the setup software of the TV and you will need to go to the manufacturer's website and ask for technical support to solve the mystery!
