I have an apex dt502 converter box that will not pick up a local channel, tried it on two different tv sets with numerous scans and no results. Another local channel comes in perfect.
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
SOURCE: cannot find channel 3 or 4 on old Panasonic TV CT 20S2S
Channel 3 or 4 is what you select on your actual television. using the TV remote press 03 or 04 ( whatever the converter box output is switched to on the back.
if you cannot get the tv to select 3 or 4 ( not programmed try searching for channels on the convertor box and after it finishes auto program the TV set.
For a more detailed specific answer please list the make and model of both the TV and the digital converter box
