Beko washing machine error code e5 Error E5. This can mean a number of things but usually involves the machine not draining properly and taking too long to go through its cycle or not spinning. There could be blockages or problems with the pump/filter or an issue with the control board.
https://www.washingmachinerepairservices.co.uk/beko-washing-machine-error-codes/
contact the machine manufacturer's customer support and you can ask them what error E5 is you could also ask for new manual and that might have error codes in it , make sure you have serial number and 12 digit number .
5E. This means the washing machine has a "water drain error". It's basically timed out on empty, it's tried draining out the water for 10 minutes and the water level still hasn't fallen below a specified level (or at least it thinks it hasn't). This error should be reset by pressing the Start/Pause button though if there is a fault it will need fixing or the error will just return.
A washing machine not emptying the water can have various causes as can a washing machine thinking it hasn't drained the water because it's possible that the signal telling the machine that the water has gone can sometimes not be triggered if a fault in the pressure system prevents it.
To troubleshoot this problem the first thing to check is the pump filter, which could be blocked. I have extensive advice on diagnosing pump faults here Washing machine won't drain water (stuck full of water) ' Faults on pressure system
