Re: MY JXD S18 MINI PAD IS IN CHINESE HOW DO i CHANGE IT...
Its an android system so it wont be diferent from a cell or even a tablet. put side by side with one or other and follow the steps necessary. hope it helped
You should be able to go to your settings and change the language to English. If not you may have to do a reset and set the tablet up again and if you do then the addition applications and data you put in maybe lost. Not sure with this tablet. I was unable to tell if you could get to your settings but I hope so. Good Luck.
the language setting is in the preference set up screen. But you probably will need someone to to talk you through how to get it.
call customer service.
Settings > Languages & input > Language > Select the one you want.
If the tablet is in another language and you cannot read any of the labels, please follow the instructions below:
Get into settings. The icon looks like three bars with small ovals intersecting them. From here, you should see a list of icons on the left side of the screen, followed by text (which may be incomprehensible). Look for the Languages & input icon which looks like an A in a white box. From the following menu, choose the very top option. It doesn't matter if you can understand the text or not - it says "language." The following menu should show a list of languages, each as it's described in that country. For instance, English is written as "English," but German is "Deutsch." In other words, it should be very easy to find the language you understand - just look for it from the list of options and it should be immediately legible. Once you tap your language option, the system language should change and you should be able to understand the rest of the system menus.
Get into settings. The icon looks like three bars with small ovals intersecting them. From here, you should see a list of icons on the left side of the screen, followed by text (which may be incomprehensible). Look for the Languages & input icon which looks like an A in a white box. From the following menu, choose the very top option. It doesn't matter if you can understand the text or not - it says "language." The following menu should show a list of languages, each as it's described in that country. For instance, English is written as "English," but German is "Deutsch." In other words, it should be very easy to find the language you understand - just look for it from the list of options and it should be immediately legible. Once you tap your language option, the system language should change and you should be able to understand the rest of the system menus. Support Troubleshooting Guide
