Question about Westinghouse SK-32H240S Television
My Westinghouse TV SK-32h240S widescreen HDTV sound muffles afterchanging channels. I also just recently changed cable companies from TW to AT&T . I didn't have the problem with TW. I calle
My Westinghouse TV SK-32h240S widescreen HDTV sound muffles afterchanging channels. I also just recently changed cable companies from TW to AT&T . I didn't have the problem with TW. I called AT&T and they sent me a replacement cable box and I still have the problem. I'm connected by an hdmi cable. Could that be the problem?
    Top Expert:
  • Westinghouse Master
  • 30,675 Answers
Before getting a replacement box, check the cables.
Posted on Oct 06, 2017
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
SOURCE: I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Jan 21, 2010
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
Aug 03, 2012 | Westinghouse SK-32H240S Television
HI...I THINK MY GRANDSON POUR BABY OIL IN THE BACK OF MY WESTINGTON HOUSE WIDESCREEN HDTV SK-32H240S. WHAT SHOULD I DO ? THANK YOU !!
Ouch! Ok... don't turn it on!!! If it's plugged in, unplug it. Get papertowels and clean off as much of the outside spill as you can. I would recommend taking the TV into a pro and letting them clean it out completely. A good TV repair shop can clean it up properly by taking the components out and reassmbling the unit. If you are electronic saavy or have a friend who is, you could possibly handle the clean up job yourself, but if the TV is still under warranty, you will want to have it professionally cleaned.
Sep 19, 2010 | Westinghouse SK-32H240S Television
Lightning struck My SK-32H240s Widescreen HDTV and now it will not work. Is there a reset button or some way to fix this myself? No insurance and 2 years old
Hi:
If lighting struck the television then there may be a problem with the power supply, first thing to check for is the line fuse, if no standby light is lit on the front when you plug the set into AC outlet then the line fuse is blown and needs replacing.
Aug 22, 2010 | Westinghouse SK-32H240S Television
Picture goes off sound stays on
Hi
Yes the problem has been solved. finally. The information on your web site was correct but the replacement board that I needed was no longer available. I ended up taking it to the local repair shop and he "worked on the board" that was messed up. Cost about the same as a new board would have, if I could have gotten one. Thanks for the great web site.
Dec 30, 2009 | Westinghouse SK-32H240S Television
SK-32H240S Gets past the "W" then goes black, with sound.
one of your transformers probably blew. had same problem with mine so took it apart and saw the problem. did some research. Darfon makes the power board and you have to buy the whole board not just the transformer. could cost you around 200 dollars. best bet is to call a local tv repair company and see if the have spare transformers for that lcd.
Jul 01, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Looking for part for Westinghouse TV TW 50621-C032E black bezel housing for TV Model SK 32H240S Piece was cracked when delievered, TV works, just need the black plastic part that is cracked. Rich
Partstore.com seems to have the part in stock. But, they don't describe if it's black or a different color.
It runs for $94.95 and their part# is 60.3YQ08.003
You may want to call them up to see if it's black.
1-866-925-7278
I hope I answered your question. Please rate me. :)
Mar 03, 2009 | Westinghouse SK-32H240S Television
Home theater hook up
Make sure u have plugged in the audio cable to the tv.
thanks..
Feb 01, 2009 | Westinghouse SK-32H240S Television
Westinghouse sk-32h240s hdtv
Lines, and the screen going black are common among this particular T.V., but some solutions to a similar problem were posted here.
Dec 27, 2008 | Westinghouse SK-32H240S Television
Televison & Video Logo
94 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
