.on any washing cycle when cycle has finished and I go to hang out clothes they have lint all through them. I have tried many different washing and clothes combinations but I think it has something to do with the machine
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
SOURCE: fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
SOURCE: washing machine not spining
You may have a problem with the rotor position sensor. This sensor is situated on the motor windings and should really be replaced by a qualified tech.
SOURCE: paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
SOURCE: My washing machine will not spin out Clothers
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
