The power supply is brand new so that can't be the problem. (The processor, harddrive, and ram are also okay, that much I know).The power switch itself works because I tested it on another computer and there was no problem at all. When I connect the power cable to the pc, the light on the motherboard goes on, so there is power running somewhere, but the switch doesn't trigger the process which makes everything start up... I am a total newbie when it comes to hardware modifications etc so I am clueless here. PLEASE help!!
SOURCE: Asus motherboard M2N-E will not power up
Try to turn on without connecting the hdd sata and see what happens it should give you the display atleast.
It could be a memory card too. I would start by pulling the memory cards and see what happens.
Is there a connection on the motherboard for your hard drive?
SOURCE: ASUS Asus P5QC Motherboard
Hello edwardfuller:
Do the same as you did, only this time remove all plug in boards and if there is anything connected to the mother board such as extra fans, speakers, and so on, remove all.
The board will detect any shorts, or overloads or problems in cards and so on , and will not turn on.
If it still will not work, check your memory sticks.
Remove all memory and place one at a time in the first slot, and then proceed to turn on and test.
By elimination, you can find the problem.
If all fails, then something may be wrong with the mother board.
take care, hope this will help,
SOURCE: Motherboard P5PE-VM doens´t get ON
Hi! Good Day, your ASUS motherboard don't have problem it's just that you have to make your CMOS jumper back to the original settings, it's near in the battery terminal. You will see a label on the board saying Close and ClearCMOS, put the jumper in close position then turn on your computer, thats it Good luck
