Question about ViewSonic N3251w 32 in. LCD HDTV
ViewSonic N3252W LCD TV went pop and completely died. No power whatsoever. Not even the red light indicator that is always on as long as its plugged in.
The power supply to the tv is fine. Other equipment works when plugged into the same outlet. Is there any quick fix or a reset power button? Nothing is evident from the outside of the TV.
    Top Expert:
  • ViewSonic Master
  • 76,237 Answers
The main power regulator board [SMPS board] has damaged. It should be replaced. Normally there is no repair to these boards. Only card base replacement is done. Check this to know more.
Posted on Jan 07, 2013
2 Suggested Answers
Anonymous
SOURCE:
SOURCE: No Power - Viewsonic N3252w LCD TV
you go to a service centre near your area who repear it
Posted on Sep 08, 2009
I have a 32 inch viewsonic model n3252w black screen with no sound .
This model has a history of power supply problems. Depending on your level of expertise on electronic repair, you can repair the power supply or replace it. The most common repair is to replace the bulging power supply capacitors.
Feb 26, 2013 | ViewSonic N3252w 32 in. LCD Television
Viewsonic n3252w psu change,pwr on screen go blue 1sec.to black
The main board will have faulty component/s. Seek tech support.
Jun 07, 2012 | ViewSonic N3252w 32 in. LCD Television
Viewsonic N3252W picture ok but no sound
Download the repair book to this TV by net. It will have all details.
May 23, 2012 | ViewSonic N3252w 32 in. LCD Television
How to reboot N3252W
Unplug the power, wait an hour, then plug it back while holding the power button down. This will reset back to factory settings and most likely will solve your problem.
Mar 01, 2012 | ViewSonic N3252w 32 in. LCD Television
I am wondering if there is an in-line fuse that may blow if there is a power surge? When tv is plugged in the red light is not on, and will not turn on..
Viewsonic 32" TV has an inline fuse. It is soldered to the power board. It is a small black cylinder. You can order a replacement fuse from aliexpress. Cost is about $1.40, but I had to purchase 10 for total cost of $14
Oct 07, 2011 | ViewSonic N3252w 32 in. LCD Television
We were watching tv and the screen went black, the sound got quieter and then it turned off. We left it overnight and now it won't even turn on. The red light isn't on to indicate the tv is off. We...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem...
Jun 26, 2011 | ViewSonic N3252w 32 in. LCD Television
I can hear but I can not see,is black, please help me
Tv first turn on the tv have a flashes of a picture a few sec,than died have audio left only?Yes,take ur tv aparts and carefully check ur tv power supply board that board where the tv power a/c cord plug into it.Carefully check the tv power supply board for dying capacitors components parts.If have dying capacitors components it usally have bulges or puffing up on to it tops.Tv could have 1 or 2 long boards that are call the LCD inverters board are dead too.If the tv power supply board it is good and have no dying capacitors parts are bulging up or puffing ups on to it tops.The tv 100% have those 1 or 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv power supply board or those 1 or 2 long LCD inverter backlight boards for the replacement.
Jun 24, 2011 | ViewSonic N3252w 32 in. LCD Television
My viewsonic n3252w made a pop sound then turned itself off, the tv is 3years old now. when i try to turn it on it tries then goes off again, if i unplug it for a while i get a picture then the same things...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
May 08, 2010 | ViewSonic N3252w 32 in. LCD Television
Sep 08, 2009 | ViewSonic N3252w 32 in. LCD Television
ViewSonic N3251w 32 in. LCD HDTV Logo
164 people viewed this question
Top ViewSonic Televison & Video Experts
lubomir73
Level 1 Expert
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
