Question about Whirlpool 3.6 cu. ft. Cabrio H2Low Wash System with Auto Load Sensing Top Load Washer"
I have a whirlpool h2low system, I purchased it a little over a year. It stopped spinning, any idea why? Or how can I fix it myself?
    Sergeant:
  • 291 Answers
Cut and paste or type this into the YouTube search bar:
Cabrio H2Low
Hit enter.
Enjoy.
Posted on Jan 07, 2013
Whirlpool Cabrio H2low is not draining after wash cycle
please check owner's manual troubleshooting. I'd guess load is, was out of balance and shut down spin cycle early.
Feb 17, 2015 | Whirlpool Washing Machines
I have a whirlpool h2low top loader washer. The sensor will not advance past the wash cycle. What should I do.
Might want to check the switch that senses when the lid is closed. It won't spin if it thinks the lid is open. That might be holding up the advancement of the cycle.
Feb 12, 2015 | Whirlpool Washing Machines
Please help me ! My Roper by Whirlpool washing machine can't stop spinning on it's own. :(
Does the tub move sideways. Try pushing the top of tub side to side at the top. There Is A Wedge That Clamps Tub To Spin Tube. Also try to turn tub with washer off, the brakes could be bad not grabbing. Sears parts direct has a good diagrams.
Mar 29, 2017 | Washing Machines
H2low whirlpool top load washer turns on, fills with water for a second and stops...keeps making a sound on the sensing mode but does not get to wash mode to continue washing.
if the washer is only one month old contact whirlpool and they will give you a service company in your area to contact and it the repair will be free of charge as long as the problem is with the washer and not something that you are doing wrong or something wrong with the way that it is installed, the unit is under mfg. warrnty for one year from date of purchase.
things to check before calling would be, water connections correct? hot to hot cold to cold. are both the hot and cold water turned on?
kinked lines?
i would call a whirlpool certified repair company, they will send a guy out and if its broken they will fix it for free.
Nov 27, 2011 | Whirlpool Washing Machines
Emerson ms3105 won't play cd's wont even spin
kungfuz...I have had two of these emerson cd players. One is in my home and is still working after 3 1/2 years. The other was purchased for our church just over a year ago and it has stopped working. The disks will turn a little then stop. Occasionally it will still play a complete hymn but this is rare. Also a grinding sound can be heard with the ear close to the unit. I think when you pushed the combo of buttons and it stopped working, this is likely just a fluke and it was probably going bad anyway. I may be wrong but I have been down this road myself and your problem sounds very similar to mine. I can't offer you much encouragement...sorry...!
Jan 28, 2010 | Emerson MS3105 CD Shelf System
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 3.6 cu. ft. Cabrio H2Low Wash System with Auto Load Sensing Top Load Washer" Logo
791 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
