One partion suddenly crashed, but still being detected by the windows explorer but not explorable. It also does not show up the software "Recover My Files" . What options of recovery do i HAVE?
Http://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 AU $8.40 Buy it Now + postage AU $0.96 you could get this on Ebay if you dont have an account you will need to create one https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account On Ebay summary page you will see on left a paypal link When you get to the paypal login page at the bottom you will see new to paypal sign up tab Paypal to create an account Paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress be very specific when you type in the search Always ask questions ? Before you make a purchase and keep the email /s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. or you might be able to find one closer for local pick up
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable
http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4 USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit AU $7.46 free postage worldwide You would have to remove the hard drive and use a usb sata ide kit you will then have to connect it to your computer using a usb port Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually click start click on computer to open you should see this drive If you dont. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X you will need to update/reinstall drivers right click to reinstall drivers. If you can see your usb drive but its not working ports (com&lpt) right click update driver Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive
hope this helps
SOURCE: wd 160d passport external hard
CardData Recovery can recover data from all camera flash memory cards includingCompact Flash Card (CF), Smart Media Card, Secure Digital Card (SD),Multi-Media Card (MMC), XD Picture Card (XD), Micro Drive, Sony Memory Stick(Duo, Pro), as well as removable storage including Zip disk, USB drives andHard drives. Recovery of files is also possible even when drive has beenformatted.
http://www.card-data-recovery.com
SOURCE: drive not detected in windows,
Did you set the jumpers on the hard drive to what you are using the drive for like master or slave or cable select. If you are putting it on the same cable as another hard drive you have to pick weather it is the master or the slave.
SOURCE: WD My Book not displayed in windows explorer as drive letter
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
I used HDD regerator 2011 and got back 95% of my lost data, so, I'm surelytoecommend the same to anyone who might accidentally got the same type of prob. However after the software continues to run all the time notifying me thatt is now monittoring al the disks & keeps on notifyng me whenever it finds a"bad sector@ it prompty repairs it rtill all drives & their partitions. successeullly.
well done hope it all worked out if it is bothering you just uninstall the software only reinstall it when necessary
