I just finished recharging. Light didn't turn green after 12 hours so I disconnected. It showed almost fully charged so I went on to the last page of the book I was reading. When I tried to turn the page it wouldn't move. It is seven hours later and it is still on. I cannot turn it off.
Then it means files of the Kindle Operating system might be corrupted in the Device. You need to reinstall the operating system in the kindle support. You can ask for the Support Kindle Technical Support Registration 877 690 9305
SOURCE: Kindle locked up and now can't get it to turn on.
I have the same problem. The screen saver is partially frozen on the screen on the upper right corner and then blank down the rest of the right side. The rest of the screen is readable and I'm able navigate (turn pages, select different books, etc).
Did you figure anything out? Help!
SOURCE: Kindle stopped working. When I
Apologies, this is not a solution, but just to say that I currently have exactly the same problem. Have you managed to fix yours?
SOURCE: 1. My kindle keeps freezing. 2. When not frozen,
I had the same thing happen to my kindle. I contacted amazon customer support and within the week they sent me a replacement kindle free of charge!
SOURCE: My kindle is frozen. I cannot reach my home page.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
SOURCE: My Kindle reboots upon start up and frequently
Is your kindle in an unlighted cover? Amazon Kindle support suggested to me that this exact problem may be caused by interference with the metal clips that hold the kindle cover on.
After taking it out of the cover, it works just fine!
This does not happen with the lighted cover apparently.
They also suggested NOT turning it off when finished reading. Hit the home key and walk away. After about 10 minutes, it will power down to sleep mode on its own.
Hopevthis helps.
