Help me
Here is the owner's manual:
http://www.manualslib.com/manual/147752/Samsung-Wf-B1061-User-Manual.html?page=10#manual
It says in troubleshooting section error 4E is a water supply issue. The screens on the watervalve may need cleaned. Remove supply hoses on back of machine to clean them. If no improvement check water pressure coming from supply hoses. If pressure is good watervalves may need replaced.
SOURCE: 4E error....samsung J845
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
SOURCE: My 7kg samsung washer always flashes error code 4E
SOURCE: operating of samsung WF-B1061 washing machine
HI SIR, I HAVE SAME MODEL (WF-1061) MY QUESTION IS THAT, THERE IS ANY FILTER TO BE CLEAN BY MANUALY,BECOUSE I FEEL BAD SMELL WHEN I OPEN THE FRONT DOOR
