Step 1:
Please adjust acordinbg the Video.God bless youStep 2:
see the next video how to loube and rollers bearing too.Step 3:
if you need to replace the deck belt please go to
www.fitnessrepairparts.com
SOURCE: walking belt folds
It sounds like one of the adjusted bolts or endcaps that adjusts the walk belt is broken,look at the bolts where you adjust and see if the side the belt is shifting to is broken.It may have ruined the belt also but you wont be able to tell till you correct the tracking problem.
SOURCE: Can I glue the torn edge of my treadmill belt?
I would question why it traveled to the right and cause you grief. Before anything else run the unit and see if its going travel to the right again if it does then check right end cap for breakage. To your first question no you cannot glue the belt they use a high temperature gluing process for the seams you'll have unfortunately replace the belt.
Testimonial: "Thanks for the advice. I'll check the machine as you suggested. "
SOURCE: the walking belt on this Lifestyler Expanse 8.0
I'm sorry to say that the belt is toast and needs to be replaced. I would also check the end caps I believed it is a one piece unit that the belt tension bolt is attached and the left side had cracked and cause this problem. Call Icon Fitness @ 1-800-999-3756 with locating the proper parts and pricing
SOURCE: 3 yr old Smooth Fitness 7.1HR Pro won't Unfold
rosenfelddav, did you ever find the solution to your problem. I have the same exact issue and would like to know how you fixed your issue.
SOURCE: Proform 730 treadmill,rusted screws won't remove to replace walking belt
Use WD40. Or go to a nearby hardware store an purchase a rust remover. Aply either one and wait for a bit. Then remove screws.
