1) tight and clean the upper and lower connector 2) tight and clean the ribbon cable for display board 3) adjust the Reed swtich , tight and clean and test for faulty or open see the diagram attached. 4) lube the deck belt see the video.
please LUBE THE deck belt, this happen because the lack of maintenance. shut down.for protecting the electronic system 2)LUBE the rollers bearing too very well 3) test the input voltage motor, if there are the motor need repair. 4) adjus the REED swtich, see the diagram , clean it, an tight any connector, or plug. God bless you
LUBE the deck belt,this happen because the lack of maintenance. may be is time to exchange the drive belt. 2) LUBE the rollers bearings. too 3) measure the input voltage motor, if there are the motor need repair 4) measure the output voltage board, for input voltage motor , if there are NOT the board is faulty. see the b. diagram attached, see my personal TIPS. God bless you
the drive belt is too loose. you need to tighten the belt that drives the front rolller, which drives the walking belt. depending on the type of treadmill there shoudl be a way you can do this by loosening the motor and adjusting that to tighten the belt. it could also be that the belt needs to be replaced and also could be the walking belt. you should try to tighten the walking belt first. that is at the end of the treadmill where you walk on it. there are two holes one on each side of the treadmill where teh belt goes back under the treadmill. there are allen key bolts that you need to tighten clockwise one turn then try the treadmill. if it doesnt tighten then turn another full turn. if not tight enough then it might be the drive belt. if you tighten the walking belt all the way then try to tighten the drive belt.
Here are two solutions one is to get the belt centered on the treadmill
and the other is to tighten the belt.
There should be two bolts
in the rear of the treadmill, one on each
side. These bolts adjust the rear roller of the treadmill. The walking
belt will always go to the side that is looser. To get the belt back
on track, (if you can start the treadmill so the belt is running)
tighten the bolt on the side that the belt has slipped to. Tighten the
bolt a little bit at a time. If you tighten the bolt too much, then the
belt will go to the other side.
To tighten the belt, start by
locating the two bolts that adjust the
rear roller (one on each side of the unit in the back). Run the unit at
about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that
what you do to one side, you MUST do to the other side or the belt will
get off center. After you tighten it 1/4 turn, check the belt to see if
it is still slipping. If it is then tighten the belt 1/4 turn again.
Continue until the belt does not slip, but do not tighten the bolts more
than 2 full turns.
Sounds like either the belt is loose or the belt/deck need to be lubed.
than 2 full turns. To lube the treadmill, use silicone spray and spray between the belt and deck on both sides. I hope this helps. Let me know if you have any other problems.
