New camera, new batteries, already formated memory card (twice!) Camera turns on, lcd looks fine, button pushes down but doesn't capture image in any mode. 800# not available over the week-end. any suggestions?
Is the small switch on the side of the SD card pushed up toward contacts? Has the card been formatted by a PC(A NO-NO)? Remove card;turn camera on..go to setup; press up arrow once to get "DELETE ALL IMAGES NO?";press select button to get flashing "NO"; press up or down button once to change flashing NO to flashing YES; press select once...should get "DONE";press select until back in "SETUP...Turn camera off insert SD card and try again...may need new SD card.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't
already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Reason is lens guide pin damaged & replacing is the final solution. But before that trey these.
cameras : My Camera Freezes When I Turn It On Or Take A Picture
P, td, li {font-family: arial, u; font-size:9pt; margin-top:0px;margin-bottom:0px; word-spacing:1px;}
If you camera freezes when you power it on or when you try to take a picture, you may have a defective memory card. To test your camera and the memory card, follow these steps:
Power off your camera.
Remove the battery from your camera. If you have a memory card inside the camera, remove that as well.
Clean out any dust or debris inside the battery compartment, and then re-insert the battery into your camera.
Power your camera on without the memory card installed.
Take a picture.
If your camera takes a picture, re-install the memory card, and then go to Step 6.
If it does not take a picture, your camera requires service. To set up service, click the Create Online Service Request button below.
Format the memory card in the camera, and then take another picture.
Important:Formatting erases all pictures and other data from the card. If you have pictures on the memory card you want to keep, download those pictures to your computer before you format the memory card.
If your camera does not take a picture with the formatted memory card installed, replace the memory card.
If the issue still persists after you’ve installed a new memory card, your camera requires service. To set up service, click the Create Online Service Request button below
1. Ensure batteries are fully charged.
5. turn on camera and see.if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Press "Menu" Press button to the right (towards a little flower on my camera) which takes you to the "setting" menu. scroll down to "format" right click again and it reads "All data deleted" and then gives you the option to "Format" or "Cancel". Select "Format" and then "ok" and pronto....your memory card is ready to go.
This often indicates a card error. Transfer all your images then format the card in the camera.
If you still have the problem, try a different card.
If you still have the problem then looks like you will have to send it in for repair.
