Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle after jumpering pins 2 and 3, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Mine just did the same thing and I can't get it to unlock. Did you find a solution so I can try it? I read the manual and did what it said but it didn't work.
mine just did the same thing and I read the manual and did what it said but it won't unlock. Did you get it fugured out so I can try what you did?
Unplug the washer and turn off the circut breaker for the washer, wait a few minutes. The door should unlock
