Goes to entertainment verizon and won't let me log in
If you are not using the latest google chrome, then you can download the new version and re-install.
if you have the latest version, the chrome might have been infected by google redirect virus. Run scan for gogle redirect virus using the google tool HERE-OPEN..
you may check how to fix common pc errors on
http://digitalpowering.blogspot.com/2013/01/fix-common-pc-computer-problems.html
SOURCE: My grandaughter cannot log in on my wi fi. She
Do you have a WEP password set up or is it a wide open connection? If it is WEP then follow these steps.
1. Right click on the Single screen icon on the task bar.
2. select change the order of preferred networks
3. remove any entries that are there
4. click add button
5. new screen put in the name of your network under SSID (case sensitive)
6. uncheck the box that says "the key is provided automatically.
7. now the network key fields should light up for an entry, so put your password in here twice.
8. make certain the network is set to Open and encryption is set to WEP.
9. Press OK and the router should automatically connect her to your internet.
Let me know how you make out! [email protected] Good Luck Phil
SOURCE: WON'T LET ME LOG ON WITH PASSWORD THAT USED TO
You can remove or change the Windows User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
SOURCE: Hello, since upgrading to IE9 from IE8, I can not
just tweak the IE9 security settings at your preference...
Testimonial: "Hello, I am not all that good with computer gargon so I will check what "tweak" is and I will do it. Hope it sorts out my problem. Thanks"
Go to www.google.com and in the search box type "download google chrome" (without the quotes). Download and install a fresh copy of Google Chrome from Google Chrome's website without losing any of your bookmarks.
Check this site for more
details. It has more than 1400 posts to
different brands of electronic entertainment and other equipments. All posts referrers with the repair and
fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide
option, can be selected by the sidebar tag at the top left of the display
screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard
option will be the best.
