Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
I have a problem with my sound for a westinghouse Tv, my dvd plays sound but when i have on regular tv, it doesnt have sound, can you help me?
    Top Expert:
  • Westinghouse Master
  • 76,143 Answers
Check the sound system settings to your Westinghouse TV.
Posted on Jan 09, 2013
6ya staff
SOURCE:
gbc_cmc
  • 20 Answers
SOURCE: Westinghouse LTV-40w1 HDC HAVE SOUND - NO PICTURE
You need a T-con Board and I have that one for $80.00.
I reclaim working components for TV damaged in shipping or returned for other reasons. Simple repair for any body with a Philips screwdriver. NO special tools needed.
GBC_CMC@yahoo.com
Posted on Jun 03, 2010
Anonymous
  • 317 Answers
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Posted on Jun 03, 2008
Anonymous
  • 3 Answers
SOURCE: No picture on a Westinghouse lcd tv model ltv-20v4
I had this problem with these tv`s. The problem actually lies with the power supply inside the unit. Some of the units i`ve seen have 2 blown capacitors on the power supply (C7 and C6) replacing these works. On others, the capacitors as well as a few transistors (Q8 - Q1) are blown. But on all the sets i have seen with this problem, changing the above components restores full functionality to the system.
Posted on Jul 20, 2009
Anonymous
SOURCE: westinghouse tv ltv46w1hd sound no picture
Need part for westinghouse LTV-46W1 no Picture
need to get Back light Inverter where to buy it.
Posted on Jul 29, 2009
Chi Chu
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
Why won't my westinghouse tv model tx 47f430s play bluray, but it will play regular DVD's just fine though?
This fault is not a user repairable one, especially to blu-ray players. Contact the authorized service center for Westinghouse.
Gopakumar Gopalan Google
May 16, 2014 | Westinghouse Televison & Video
5 yr old Westinghouse TV w built in DVD player. DVD player won't play. Tried several different movies, none will play.
First thing I would check is that you are playing regular DVDS and not BluRay. Your TV may be old enough not to accept BluRay. If it doesn't work with a regular DVD then you most likely have a bad reader which can be replaced but you will have to take the tv apart to get to it.
Dec 12, 2013 | Westinghouse Electric SK-32H570D 32 in....
When my tv is playing regular cable the volume doesnt work but when i play a dvd in the dvd player volume comes out of the tv, whats wrong?
Good--sound when playing a DVD means either a setting is wrong and it can be in the set or a box if connected---it also means the audio output circuit is good.
Worst case is where sound is developed by the set's tuner there may be a problem but check all audio settings first---
Jun 12, 2012 | Hisense LHD3204US 32 in. LCD HDTV
My Westinghouse 32 does not play sounds for my video games for my PS3
Your signal board is bad and will need replacement. If you open up your tv and look at the signal board you can get a part number so that you can order one.
You can get get parts for this tv at www.interliquidparts.com
Nov 18, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My Westinghouse TV LCD has no sound but has picture please help? 32 LCD westinghouse
there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered.
First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV."
Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so."
If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again.
To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.
Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me.
Regards.
Oct 21, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Jul 15, 2009 | Westinghouse Electric VK-40H580D 40 in....
Westinghouse DVD/TV combo has no sound
i'm sorry i didn't notice the "dvd/tv combo". the dvd mech inside the tv will need to be replaced.
Jan 21, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Westinghouse TV/DVD password
If all else fails, contact Westinghouse customer support. You can call Westinghouse at (866) 287-5555 or email them at service@westinghousedigital.com. There is also a helpful FAQ section on the website (see link in Resources).
Nov 13, 2017 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
1,166 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
