We have the answering machine set to 4 rings. When people call, the machine picks up on the 4th ring, it beeps, then cuts off. No recorded message. No message is recorded, the call is disconnected. What do we do?
298976e2-a owners manual,
i have same problem,
sorry if my english not the best.
i "paste and copy"
send me email.
[email protected]>>>Canada
my phone i by new, 1 week ago' and complet empty
the memory,
Why i have to pay again online to have assinstence?
the company not give any assinstence any more?
ge-298976
I'm assuming this is a digital recorder and does not use a tape. Any chance the memory is full and you need to erase messages to free up space for new recordings?
To make sure the printer picks up
incoming faxes, set Auto Answer to On, and then set the printer to pick up
after a greater number of rings than the answering machine. For example, if the
answering machine picks up calls after four rings, then set the printer to pick
up after six rings. This way, the answering machine picks up calls first and
your voice calls are received. If the call is a fax, then the printer detects
the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the
same telephone line if you subscribe to a distinctive ring service offered by
your telephone company. This feature allows you to have multiple telephone
numbers on one telephone line. Each telephone number has a designated ring
pattern (single ring, double ring, triple ring, or double and triple ring). The
different ring patterns let you know which telephone number was dialed, and
which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
The exact same thing happens to us! It will pick up, click then disconnect. Nothing else happens. Our memory is fine, there's plenty of space so that can't be the problem. Any other suggestions?
i have the exact same problem...
shall we contact GE ?
