Question about Nikon D40X Digital SLR Camera Digital Camera with 18-55mm Lens
Hi, i am using nikon d40 my problem is that i was using 18-55 lens after some years there was green spots on my pics when clicked,i started using 18-105 mm nikkor lens my problem was solved but now af
Now i use 18-105 nikkor nikon lens with Nissin Mark II Di 622 digital TTl Flash.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Nikon Expert
  • 305 Answers
Problem solved the green spots were from the sun use your lens hood thats what its for
Posted on Aug 06, 2014
6ya staff
SOURCE:
Anonymous
  • 121 Answers
SOURCE: nikon d50 and lens
I don't have this kind of camera myself, but on my Canon D350 there is a switch on the lens that sets manual/automatic focus. Mine is marked MF/AF ans is just a simple switch. Check to see if this might be the case on yours, too. Also check the contactts on the lens and camera to see if they might be dirty. And be very careful not to get any dust into your camera housing! -Chris
Posted on Mar 09, 2007
Anonymous
SOURCE: Nikon D80 Autofocus problem
Try re-setting the camera? On the D40 it is 'Menu' scroll down one to Custom Setting Menu (a pencil) and click reset 'ok' yes 'ok' this worked for me.
Posted on Sep 09, 2008
Jeff Marcus
  • 115 Answers
SOURCE: Nikon D70 lens won't let me shoot
Remove the lens being careful not to get dirt/dust in the camera(very important).
Clean the metal contacts around the lens and on the camera where the lens and camera meet. Your error sounds like a lens communication error.
Again!!! Do Not Get dust/dirt/moisture/ anything in the camera.
Posted on Apr 10, 2009
caroldon
  • 17130 Answers
SOURCE: my nikon digital camera flash
Not to worrry, the possible fault is with the failure of your flash unit. This unit is embedded into the camera and is a very arrangement which is not advisable to be opened by anyone less experienced. The best solution is to get the camera serrviced at the NIkon authorised service centre which is in Mumbai. You can get the exact address from any dealer who is selling the Nikon cameras. Get an estimate before you can give it for service as sometimes the woork may get very expensive.(web search for Nikon service centres in Mumbai -India) If you are choosing any local serivce centre be very careful not to get it tampered for total failure. Otherwise after your review decide on the job or use the camera as far as possible in daylight or you can use good lighting when shooting. Good day
Posted on Aug 03, 2010
SOURCE: I used the Nikon D90
That's the Nikon error message for a lens with aperture ring set to something other than the minimum (i.e. highest number).
The camera insists on controlling the aperture ring, and to do so, the ring must be set to the minimum setting.
Unless it is a "G" lens, which has no aperture ring whatsoever.
The camera body sets the aperture of the lens wide open while auto-focusing, and displaying through the viewfinder. When it comes time to flip the mirror up and take a picture, the camera dials the aperture to the setting you (or the camera) have selected.
Posted on Dec 22, 2010
Repair a broken hot shoe mount on the speedlight
Have to try tighten down the four screws holding the shoe?
Would you like me to fix it for you?
If it is just the Hotshoe Assy, then you can buy from me.
They come in two versions:
Nissin Di866
Nissin Di866 Mark II
Are you from USA?
Truly,
atdlee@netzero.com
Aug 12, 2014 | Nissin Di866 Digital Flash TTL for Nikon...
Replace bulb
You will need to contact Alzo Digital in CT, USA for parts or they can get you to the right person.
May 27, 2014 | Nissin Di866 Digital Flash TTL for Nikon...
The D40 is a low end camera, but before you discard it, I would contact the closest Nikon repair depot (see the Nikon website for the location) and ask them for a repair estimate. You will then be able to decide if it is better to have it repaired or replace it with a newer model.
Jan 08, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Spare bulb for nissin di866
Contact Alzo Digital, CT, USA.
They will be happy to get you to the inventor.
Mar 15, 2012 | Nissin Di866 Digital Flash TTL for Nikon...
My nissin di466 block my Canon 450D. After couple shots or sometimes after 20-30 shots with nisin attached and turned on on my Canon, the camera block, I can not take a picture the AF did not work. Turning...
my Nissin Di466 had all the lights playing up at the back with nothing really working. I took out the batteries to find one had leaked. have know cleaned it up with it turning on ok, but dose not work on camera through ttl. Will not flash when shutter pressed.
Oct 01, 2010 | Nissin DI466 Power Zoom Speedlite Nikon...
How to setup the nissin di866 digital flash to canon eos 50D?
Set camera to ASA/ISO 400, set in P, set lens in A.
Park flash on hotshoe.
Press White Button and wait until Pilot turns Green.
Press Set Button then to move those Arrow until it covered TTL(White on Blue).
Turn on camera.
Enjoy shooting.
Above is basic flash shooting set-up.
a.l9609@gmail.com
Jan 28, 2010 | Nissin Di866 Flash for Canon
I have a sunpak 622
Sunpak does not offer dedicated (TTL) module to any digital cameras. The flash can only be used in auto mode, while the camera is set to full manual. The lens has to be stopped down according the working aperture on the flash, correct exposure will be maintained by the built-in sensor of the flash. Fire the flash using a simple hotshoe-to-PC cube if your camera doesn't sport a PC connector. Trigger voltage of the 622 is safe.
Jan 31, 2009 | Sunpak 622 Super Pro TTL Flash
Nikon D40X Digital SLR Camera Digital Camera with 18-55mm Lens Logo
69 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
