You can download the manual and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/camcorders/flash_memory_camcorders/fs10#BrochuresAndManuals
If your computer won't turn on, try each of these steps:
Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
Make sure that the power adapter is properly connected to the power port on the back of the computer.
Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
Reset the computer's PMU, SMC, or PRAM. Refer to the instructions for your model:
Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord.
If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to the nearest Apple Store or Apple Authorized Service Provider (AASP) for diagnosis. If you plan to visit an Apple Retail store, make a reservation at the Genius Bar using
Canon does not support basic software to actually download your video back to your PC. It is propritary software, and it is not available from the Canon poorly run web site. i.e. It is completely worthless by itself
try You can force a frozen MacBook Air — or any current Mac laptop — to shut down and restart without removing its battery. You just hold down the power button for a few seconds until the machine shuts off, then wait a few seconds, then turn it on again.
I experienced the same thing. The compact power adapter is simply the power cord used also to recharge the camcorder. Plug it into the wall at the same time as you have the USB plugged into the computer and it should be able to download.
1.Unplug the
JVC compact component power cord from the power outlet. 2.Unplug any
connected devices. 3.Press and hold
the JVC compact component power button for five seconds. 4.Plug the JVC compact component power
cord back into the power outlet and turn on the JVC compact component 5.Open the
menu to confirm that the JVC compact component is responding again. 6.Turn off the
JVC compact componentand reconnect the devices. 7.Turn on the JVC compact component...
That is odd. I have had a fantastic experience with my MBA so far. The good news for you is that, since you have a MBA, you are probably within the 90 window in which you can seek unlimited complimentary support from Apple.
If you are close to a retail store, take it to the Genius Bar. Otherwise, check out this link for info on phone support:
http://www.apple.com/support/complimentary/
If your Macintosh computer won't turn on, here's how to troubleshoot it. Please keep in mind that although your computer may display similar symptoms that prevent it from showing video, this article discusses what to do if the computer won't turn on, meaning that when you press the power button:
You don't hear a startup chime
You don't hear any fan or drive noise
The power button or power indicator doesn't light up at all
If your computer doesn't display any video, it may display one or more of these similar symptoms when you press the power button:
You may hear a startup chime
You may hear fan or drive noise
You may see the power button or power indicator light up
Reset the computer's PMU or PRAM.
For a portable (iBook or PowerBook), click here for instructions.
For any other computer, click here for instructions on resetting the PRAM.
Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord. You can get a replacement cord for some models here.
If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to your local Apple Store or Apple Authorized Service Provider (AASP) for diagnosis.
