Kenmore 659 Electric Dryer Logo
Posted on Nov 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore elite electric dryer catalyst model
I just recently got this dryer used. It was sitting out in the cold for a few days so I brought it in the house and let it warm up for an hour or so before plugging it in. I just hooked up my 220 line for it and when I plugged it in the light on the inside works fine but no power to the digital buttons at all. Dryer wont do anything
  • stormandkim Mar 24, 2009
    I Have the Same problem. My Dryer has no display but the inside light works! IT MAKES ME CRAZY... Because once in a while it will work fine for a few days.. and then """POOF""" no display! It seems to have a mind of its own! My matching Catalyst Washer has the same sort of issues. And with both (washer and dryer) when they do work they wount always let me change settings. The dryer will only work on [perm. press]. I think there is a short some where in the display .. or it is a problem with the 'computer' in it.
Sal De
Level 3:
  • Kenmore Master 2,699 Answers
  • Posted on Nov 09, 2017
Sal  De
Kenmore Master
Level 3:
Answers
2699
Questions
0
Helped
1002362
Points
8029
Did it run before you got it?also what's the model number on the dryer,open the door look around where you put the clothes in and you'll see a tag with the model and serial numbers on it,kenmore doesn't make anything the only way to tell who made it is by the model number,110. is whirlpool,417. is frigidaire,send the full model number,things to check and that it's wired correctly,not being a wiseguy but i've seen them wired wrong,open the door and check the door switch,push on it and you should hear a click and the light should turn off and on,if that's good make sure the belt isn't snapped,most dryers have a belt switch,if the belt breaks the dryer won't run,if that's good your gonna have to get in there with a meter and check the thermal fuse and t-stats on the blower wheel housing and on the heater box,these are the easiest things to check and hopefully you'll find something wrong or one of the t- stats popped.if the thermal fuse or high limit is popped clean out the duct that the lint filter slides down into,if the dryer can't move air because it's blocked with lint one of the t-stats will pop as a safety,you said you just hooked it up so it's not a blocked vent line also you could have a bad cycling t-stat or a grounded heater,if the dryer runs to hot one of the t-stats will pop and the dryer won't run,it's easy to check the heater,just stick one of your leads from your meter on the metal outside case of the heater and touch the other lead to one side of the element,do this to both sides of the element one at a time,if you get a reading the element is grounded if not it's ok.hope this helps you out if you need more help send the model number
2 Related Answers
Anonymous
  • 42 Answers
  • Posted on Jan 27, 2009
SOURCE: kenmore catalyst electric dryer. about 3 yrs old.
You may only be receiving 110 volts, instead of the 240 volts needed to operate. (Thus, only the light coming on)
Did you reset the dryer circuit breakers?
Are you receiving 240v to the plug?
-Chad
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Aug 02, 2010
SOURCE: kenmore catalyst elite washer fills but does not
the reset is to unplug the washer for 5 minutes, if that doesn't reset it u may have a defective motor controller circuit board
The air drying the clothes is cold, not hot. We have a Kenmore Elite Electric Dryer, Model 110 63952100
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
1helpful
Kenmore catalyst elite washer fills but does not
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Kenmore catalyst electric dryer. about 3 yrs old.
-Chad
Kenmore Elite HE3 dryer stays cold
you probably need a new heater element.
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Manuals
I thinkl you can order the manuals from www.sears.com under the parts tab enter your model # also if it is an electric dry it is 220v with a neutral leg check with the local electrian to see if the power there is phased..Hope this helps
PS::The washer and the refrig will work on the tranformers
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
