Computers & Internet Logo
Posted on Jan 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Been a Quicken user for years and recently went to reconsile an account and noticed some 2007 entries appeared in my 2008 register. Why? How? I had not made an error in the dates.
Anonymous
Level 3:
  • Master 553 Answers
  • Posted on Mar 26, 2010
Anonymous
Master
Level 3:
Answers
553
Questions
0
Helped
221964
Points
1655
It's most likely these entries hadn't been reconciled when you did your year end change.
2answers
How do I get rid of Quicken error cc-501?
Follow the steps given below:
1.Press Windows + R and then type "appwiz. ...
2.Find Quicken entry and right-click on it.
3.Choose Uninstall and make sure that all the temporary files are removed.
4.After that, download and install Quicken.
5.Now, enter your account details and check whether Quicken Error CC-501 is resolved.
https://www.youtube.com/watch?v=ZAvyVeed3m4
2answers
Need a manual for Quicken essentials
You may browse on how you can use your Quicken through Intuit's website from this LINK. Choose appropriate Operating System.
I hope this works for you. Kindly comment for further assistance. Thanks for using Fixya!
Mongkey
"Understanding explains better..."
1helpful
How do you change VAT rate on Quicken 2002
You cannot do this on the normal account register, as you might have done in earlier versions of Quicken. You have to use two special registers, by creating a BUSINESS BILLS and a CUSTOMER INVOICES register. To do this tap the CREATE NEW ACCOUNT button, in the MY FINANCES screen, and select these registers from the dialogue box. When you receive a payment from a customer, open the CUSTOMER INVOICES register. Then... 1. Tap the TYPE box, and choose INVOICE from the drop down list. This will enter INVC into the box. 2. Look at the button under the BALANCE column. Instead of the usual SPLIT button, this is now labelled FORM. Click on this, and a Customer Invoice Form will appear. Fill in the details from the invoice you have received. Under AMOUNT enter the amount received, less VAT. In the V column, enter the symbol for the appropriate VAT RATE, and Quicken will calculate and enter the VAT amount. 3. When you have completed all the required boxes on the form, click the SAVE AND DONE button, and The form will close. 4. You will see that Quicken has entered the details in the correct Registers. I 5. When you produce your VAT REPORT your item will appear with its details in the correct places. The process for entering a payment is similar, but you will then be using the Business Bills register. Problem solved ! John Cunliffe
Unexpected shut down when clicking to another area My QUICKEN 2001 has began to shut down when I click to go to another feature...like Savings to Checking, for instance.Now it seems that every time I click...
Hi.
If Quicken is shutting down you won't be able to access your accounts.You need to repair the software first.
All you can do is trying to start in safe mode by pressing F8 on startup and check if Quicken can start in safe mode.
If the problem started recently, you can try doing a system restore to a date before the problem started. You find System restore from Start button at:
Start>Programs>Accessories>System Tools>System Restore
If that does not fix the problem, then you need to reinstall Quicken using the software CD and your licence number. If you choose to reinstall on top of the existing installation you wont loose any setting (repair).
If quicken does not reinstall from current account, then create a new account with administrator privileges and then reinstall quicken from the new account.
If you are still not able to remove and reinstall the software you can try using the free Microsoft utility available here to remove recently installed software.
Note: A new Quicken setup does not delete your data, but there is the chance that data had been previously damaged. In that case you can use a recent backup, or try recovering damaged data, see Basic troubleshooting to correct data file damage
Regards.
I am attempting to transfer Quicken 2008 qif files to the new IMAC, I just purchased. I made an export file...the IMAC only has Quicken 2007 installed. I have been unable to locate a 2008 or 2009 program...
go to this site for some gray tips on how to perform this:
http://www.google.com/search?q=how+to+transfer+Quicken+2008+qif+files+to+the+new+IMAC&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
4answers
I need to know what my password is for quicken 99
Have You Lost Your Windows Admin Password?
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
I purchased Quicken 2008. After opening, it crashes right away. What is the cause?
You can check your Windows logs or Quicken forums to find out about that first, then ask here once you've done the basic legwork. I can't help but notice you've caled it an Acer PC Desktop problem but that you've somehow focused in on Quicken 2008; No.
Read the system requirements on Quicken 2008; odds of fuzzy bagels to uneaten lox say your PC doesn't meet them.
1. Downloaded and registered Quicken Deluxe 2008 but did not receive ID and password info that I have previously done with Quicken. 2. Have done a download from bank on 2 accounts, then downloaded data...
That means that there end has had a problem. You will just need to wait until they get there servers working again.
Hope This Helps,
All The Best,
RCF
4helpful
2answers
Tool Bar missing at start up
Edit > Preferences > Quicken Program > Register
Uncheck "Maximize my register view".
Quicken99 incorrect reconcile date
Boy oh boy ... I thought I was behind! Is this a current question or a very old one - I cannot tell.
Normally quicken will use the last date you recondiled as the start date.
I guess you dont use the download method of reconciling? If you have WWW access on the computer where your Quiocken resides, your financial institution probably offeres this kind of service. My bank does not charge to have Quicken get the info and reconcile. And I can be as up todate as "yesterday" with this method.
I hope I have answered your question
Grand Canyon Tech
Grand Canyon Tech
