Toshiba 42H81 42" Rear Projection Television Logo
Posted on Jan 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lock Button on Coby TV FlatScreen
We pushed the lock button by accident on the front of the TV and now it won't unlock. Any ideas on how to unlock this?
Anonymous
Level 2:
  • Expert 54 Answers
  • Posted on Jan 21, 2009
Anonymous
Expert
Level 2:
Answers
54
Questions
0
Helped
15594
Points
107
Try to see the manual of that tv or try to ask help of tecnicians thanksss and hope to help you
  • Anonymous Jan 21, 2009
    try to see the manual of that tv or try to ask help of tecnicians thanksss and hope to help you
  • sonya f
    sonya f Nov 08, 2013
    I brought the TV from a thift store and it didn't come with a manual.
1helpful
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Accidently pressed the FDA button on my RCA TV and now its locked and wont turn on and i dont have a remote to it
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1helpful
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
The FDA is lock and the TV wont stay on
Hello
The lock of RCA TV can be unlocked. You must have its original remote control to do this. If you haven't one, buy a new one or just borrow it from any of your friends or relatives who own the same model RCA TV you have. To unlock it, try these methods. One amoung them will surely unlock your TV.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1helpful
I accidently locked my TV. I have no idea what the code is. When I switch on the TV there is a blue screen with lock written on it. The remote control is CHUNGHOP RM-441e Universal PLZ do help. The Whole...
Hello
You can unlock the FPA lock of your RCA TV. But, you must ahve its original remote control to perform the proceedings. if you haven't it original remote cntrol with you now, just try to buy a new one, of just borrow it from any of your friends or relatives who owns the same model Tv.
One amoung the above process will surely unlock your RCA TV. OK.
Rca 27'' tv set can't acess cable chanels with remote or tv buttons tv was in fpa mode by mistake got out of fpa mode but when i push tv buttons lock on again
Hello
Just unlock its FPA by any one of below mentioned process. Reset the V-Chip settings later and try.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Any one amoung the above process will unlock your GE TV. After unlock, you have to do the Vchip-Set.
2answers
I was trying to look for the input, and accidently locked the screen
You will need to have the remote:
Press the VOL+ on the remote control and the CH+ button on the front of the TV.
The TV will prompt you to enter a new password.
2helpful
My tv logik lk 74n has locked. please help me procedures of removing the padlock symbol.
The Red Lock indicates that it has been Child Locked, this could be done by accidently pressing child lock. On your remote control there is a MUSIC button, to turn off the red child lock PUSH & HOLD the button. The red lock does not go off with a qucik push. You need to Push & Hold The music button for about 10 secounds.
Read more: How to unlock my logik tv , it has a red lock on the corner with a blue screen and i cannot use my remote or the keyboard to activate the menu ' Answerbag http://www.answerbag.com/q_view/516852#ixzz289vnGLRC
3helpful
Citizen house tv that has a 'lock' logo on screen
The TV has been 'Locked'. To unlock it press the DISP button for 4 seconds. Since you have a universal remote and there is no way to determine which button is the DISP button try holding each button on the universal remote for 4 seconds until, hopefully, you find the correct one.
UNLOCKING THE FRONT LOCK CONTROL
hold it in and it will change. mike
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
