Washer flashes d5 error code? Amana
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
A d5 error code usually means Sd. This error code is displayed when the control detects the basket has not seated on the hub or that the pressure switch has detected a Suds-lock condition. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed. The fault is caused by using the wrong detergent or excessive amounts of detergent.
Note: If the Hard Reset does not work, there may be an internal failure with the washer.
AMANA NFW7200TW CODE 25
