Sony DAV-DZ560 Can I use a record deck and put it through the surround sound to play vinyl's
Hello, please can you tell me if it is possible to connect a record deck to the Sony Theater System DAV-DZ50? I am looking to purchase a record deck and hoping I could use the surround sound system to listen to the music. Many Thanks. John My email address is jhall1@fsmail.net if this is easer to reply?
  • john hall Jan 10, 2013
    Can you recommend some record decks to suit this Sony system and where to purchase from?
  • Steve K Jan 10, 2013
    The sony ps-lx300 that is sold at best buy should do the trick. It has a built-in preamp.
    Genius:
  • 1,054 Answers
Shouldn't be a problem as long as you get a record player with a built-in preamp. Old record players did not have a preamp, and will not output a signal at a high enough level to be used through the sony system.
Posted on Jan 10, 2013
Anonymous
SOURCE:
ginko
Ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Anonymous
  • 4 Answers
SOURCE: sony compact AV SYSTEM DAV-S400
Hi Joey - I had exactly the same problem.
In my case, I followed the advice of others and took the thing apart. On the main amp board there is a large brown capacitor. Mine had come completely loose, so I soldered it back in place with a good amount of solder to make sure the contacts were ok. I also dabbed some solder on the headphone connectors on the same board (just follow the wire from the headphone socket to the board). Well, when I put it back together and tried it again everything worked perfectly, and it has so far remained free from the error. Hope that helps !
Posted on Nov 27, 2008
Anonymous
SOURCE: i want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
Anonymous
SOURCE: COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
Posted on Jun 04, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Sony Bravia THEATER DAV-IS10 echo problem.
It's probably a user setting problem.
You don't say if you're listening to native multichannel soundtracks as intended (AFD Direct) or if you're manipulating them with one of the simulated soundfields. Simulations only go so far toward reality and they always insert artifacts.
Take a look at the Troubleshooting section in the manual. Voice tracks are mostly center-channel related.
Posted on Mar 30, 2010
Testimonial: "Have set it back to AFD Direct though one of the DVD's still sounds the same. Maybe it's the DVD. Thank you for your help."
Hi i have an old sony DAV-S500 stereo system and would like to set up an ipod to play through it, How do i do this? Is it even possible?
For just listening, any audio device with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the iPod manual because they want you to purchase expensive accessories like docking stations. You'll still have to control the music from the portable device. Oh well.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Sep 08, 2011 | Sony DAV-S500 System
Mar 30, 2010 | Sony DAV-IS10 System
Hello, I need replacement speaker terminals
Please let me know connectors color at back of unit to provide you info for speaker cables.
Nov 29, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Oct 26, 2008 | Sony DAV-S400 System
Oct 15, 2008 | Sony DAV-S500 System
259 people viewed this question
Ekse
 Grubhead
Grubhead
