Question about Sansui 32" TV
Sansui tv won't turn on
New Sansui 32" tv won't turn on after Power outage.
    Top Expert:
  • Sansui Master
  • 76,177 Answers
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Posted on Jan 10, 2013
  • Doris Smith Jul 15, 2013
    I have the same problem but if I leave it unplugged for at least and hour it will come back on. Is thhis a defect too?
6ya staff
SOURCE:
Power outages happen and tv will not come back on. Before have waited days and it will finally turn on.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Feb 27, 2016 | Sansui 32" TV
Won't turn on after unplugging sansui
Leave it plugged in for about an hour for it to warm up than it will work like normal. I have this problem every once and a while
Feb 02, 2013 | Sansui HDLCD3250 32 in. LCD TV
Where is the fuse on my sansui LCD 24" tv?
contact the manufacture or open and look inside
Dec 27, 2012 | Sansui Televison & Video
Sceptre tv won't turn on after power outage
You may have to open it to see if the line fuse that the power cord goes to is good or bad.
Dec 23, 2012 | Sceptre Televison & Video
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
My Sansui 32" Model LCD32hbw got stuck with the
Sure the power supply si working and the processor seems struck up to trigger the power but is not responding to the remote. So it is important that the main processor is checked to fulfill the working. Check for the +5 rail voltage, check for the input /output data, check the remote feed of data and the crystal oscillator.
It is possible that there is a failure around the processor or the memory.
Sep 03, 2011 | Sansui 32" TV
Sansui mdl hdllcd3210 will not turn on.
Did power signal lights appear?If there's no power signal lights,check the fuse,located at the power supply.If the fuse is good,maybe the power supply is dead.There's a leak capacitor in the power supply.Try to replace all the leak capacitor..The leak capacitor can identify through visual checking when you didn't know how to use tester.The leak capacitor is rounded top shape and have moise at the top,compare to flated shape of good capacitor.Thanks,hope will it help you..
Aug 26, 2011 | Sansui 32" TV
Tv has been turning off right after you turn it on then after a few attempts it would stay on now the power button on front turns green, it tries to come on but then turns off.
Sounds like high voltage power supply has gone bad. You can try purchasing new PS online and replacing yourself if handy or you will need to bring in for service.
Mar 04, 2011 | RCA HD52W59 HDTV Projection Television
Power Outage Problems Sony Bravia 32" LCD TV
try cycling the power (unplug 2 minutes) and plug in and wait 30 seconds and turn back on. if this doesn't work, could have been a surge, your protector should have saved it, but could have been through cable or something. surge protectors will guarantee no damage for several years, check with the manufacturer maybe they'll cover the repair.
Jun 01, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sansui 32" TV Logo
1,021 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
