Maytag dryer heating element does not turn off when tumbling stop
Older Maytag dryer LDE410, the heating element does not quit heating when the tumbling stops (door opened). Heating element only turns off when the timer runs down to 0.
samsung electric dryer wouldnt heat up ,so changed the heating element,along with the thermostat,thermostor,and two other s,now when you set the timer it goes all the way down to one second,but wont cooldown and shut offsamsung electric dryer wouldnt heat up ,so changed the heating element,along with the thermostat,thermostor,and two other s,now when you set the timer it goes all the way down to one second,but wont cooldown and shut off
You can't post conmments that contain an email address.
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
The heating element is burnt out. Unplug the dryer. Follow the wires from the control panel. They will go to the heating element. The element is probably held in by anywhere from 2 to 6 screws. Remove the screws and you should be able to pull out the element. The element is coiled wire that heats up when power is applied. If you look closely you can probably see a break in it. To get a replacement you will need the model number which will be on a metal plate either on the back of the dryer or inside the dryer door. Take the old part with you so you can do a comparison and make sure you get the right part.
