ASUS Eee 4G Notebook Logo
Posted on Jan 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Asus eee pad will not turn on after chatging on and off docking keyboard, getting green light for full chage
David Payne
Level 3:
Top Expert:
  • ASUS Master 14,162 Answers
  • Posted on Aug 18, 2015
David Payne
ASUS Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2996089
Points
455836
5 Related Answers
mowcius
  • 155 Answers
  • Posted on Aug 03, 2008
SOURCE: Asus eee PC 900 keyboard
Please don't multi post the same problem.
Your keyboard will obviously show the wrong thing still but if you go into settings, personalization, keyboard layout you can then change the layout.
I'm afraid I don't think that you can buy a new azerty keyboard separately as an eee pc spare part. Maybe you can if you contact asus.
Hope this helps,
Mowcius
Anonymous
  • 358 Answers
  • Posted on Jul 15, 2009
SOURCE: keyboard for my ASUS Eee PC 1000H is not working
Hello, I'm not actually sure if you can do this by yourself, or you might just have to get a technician to fix it for you.
What I would suggest that you should do is to get a replacement keyboard for the laptop, you can even buy it from an electronics store by yourself and get a technician to fix it for you (If you cant do it by yourself), this way it would be cheaper.
This is because it is not always advisable to try and repair a laptop keyboard, because one way or the other, it would still develpo problem again. So its better you change it outright and put the inconvenience behind you.
Hope this helps.
durtopian
Toby Lee
  • 409 Answers
  • Posted on Aug 11, 2009
SOURCE: Asus Eee PC keyboard won't re-attach to the motherboard. Help!
On the backside of the connector where the ribbon goes there is a small strip of plastic there.LIFT IT UP ON BOTH ENDS,SLIDE THE RIBBON DOWN INTO IT.WHILE THE RIBBON IS IN IT,PUSH THE STRIP OF PLASTIC BACK DOWN MAKING SURE THE RIBBON STAYS IN PLACE (ALL THE WAY DOWN) WHILE PUSHING IT DOWN.You may have to try it a few times to get it snug in the motherboard connection.Good luck!
Anonymous
  • 61 Answers
  • Posted on Mar 28, 2010
SOURCE: remove keyboard on asus 900hd
Usually you have to remove the panel between keyboard and LCD by prying it up after taking the screws out. Then you should find two screws at the top of the keyboard, then pull the LCD and remove the entire top of the laptop, the mousepad in screwed to the top. Remeber to pull all screws from the back of the laptop before doing anything.
Anonymous
  • 551 Answers
  • Posted on Apr 10, 2010
SOURCE: Some of the key on my asus eee pc keyboard don't
replace the keyboard. the structure of the keyboard of a laptop is different in the structure of the keyboard of the desktop.
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
I can not get my Asus Eee Pad TF101 to charge at all
Try another AC outlet. Maybe the AC jack has been damaged, due to pulling on the cord? Maybe the battery is dead? The cord you used is damaged, Was the other cord you tried the EXACT same power spec? If not it could fry a component.
Docking connector port
you can try this; http://www.ebay.com/itm/ASUS-Eee-Pad-Transformer-Prime-Keyboard-Docking-Station-w-Battery-TF201DOCKCG-/140738340615?pt=US_Tablet_Accessories&hash=item20c4a8a707#shId it looks as though they may ship to your location.
or you could try here; http://www.pcrush.com/product/Docking-Stations/767862/Asus-DOCKING-STATION-CHAMP-FOR-TF201-CONTAIN-POLYMER-22?refid=1238
they are cheaper but for international orders it looks like you may have to buy in bulk. it doesn't hurt to check though. best of luck!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
How do i transfer photos from a usb stick to asus transformer
You need to get the Asus Transformer Keyboard Dock. It has 2 USB port built in.
Buy it here on amazon.
Otherwise you need to a microSD card.
2helpful
2answers
Eee pc r101 keyboard not working properly. Some of the keys won't type the correct letters and type the function letter or symbol instead or just random numbers. Also the touch pad and mouse click is...
The keyboard takes a lot of abuse and as durable as it is, they will eventually wear out. It is a very inexpensive part to replace and does not require a lot of skill. The fact that the touch pad is acting up could indicate that they are interconnected. I would replace both. The Touch pad is a more involved part to replace and I would suggest you get some help or pay to have it replaced.
You can order them off of sites like eBay, then watch a YouTube video on how to do it.
I punched in:
ASUS Eee keyboard and got several results like:
http://cgi.ebay.com/ASUS-EEEPC-EEE-PC-1001H-1001HA-1005HA-Keyboard-US-Black-/220660299406?pt=PCA_Mice_Trackballs&hash=item336060f68e
ASUS Eee touch pad:
http://cgi.ebay.com/Asus-EEE-PC-1005HAB-Palmrest-Touchpad-Cable-/330585537844?pt=LH_DefaultDomain_0&hash=item4cf86efd34
These are ramdomly selected:
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
