LG 47lw5300 47-inch 1080p 120hz Cinema 3d Led-lcd Hdtv With 3d Bray Logo
Randy Williams Posted on Jan 12, 2013
Why do bright colors bounce on my lg tv?
Bright colors especially reds bounce up and down on my 47" LG 3D TV.
Ryan O'Hearn
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 23, 2014
Ryan O'Hearn
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1060
Points
I had this issue on a 40" Seiki TV. I turned off the 120hz setting and also the Noise Reduction settings in the Menu and it stopped.
3helpful
Our brand new LG TV loses brightness whilst you are watching a programme.
Check to make sure that eco mode is turned off. It will sense the ambient lighting and if it is bright, the TV will be bright so if you are seeing the brightness change...check that setting first.
1helpful
2answers
Red green lines across my screen on 51 inch tv hdtv
If you cannot align those crosses, then the convergence section is damaged. should be repaired by a qualified technician, its a big job.
Touch of snow on my screen
google software upgrades and try. if not look at Z-Sustain or maybe Y-Sus
3d picture
multicolored 3d effect is a problem with what is known as convegence... ussally there are two large chips (ic) that blow. gennerally they have to be replaced mabe some fuses and resistors..
Monitor Coloring
Well most monitors come with 2 preset color temperatures and the option to customize it(the rgb setting). Your monitor has them as well 6500K or 9300K. 6500 is more reddish(like outdoors) and 9300 is more a bluish white(like a tv, i like the 9300 more). How u said its red and bright, what i would do is set the 9300 preset and if its still too red the customize the RGB by lowering the red. and If too bright then Lower the brightness(Press down on BRIGHTNESS CONTRAST page). If you don't have the manual you can download the full manual from LG's download site here: http://www.lge.com/support/manual. If you see that you can't get it just right,then the monitor might need adjustment from inside and you should make a qualified technician open the monitor and adjust that for you. Hope this was helpful.
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
