Question about Yamaha DGX630 - Digital Piano
Yamana DGX 630 E keys make strange sound
I have a Yamana DGX 630 and after the kids played with the piano, I noticed that many of the E keys make a strange sound like two notes played together or something... tried reset but didn't work. Are there any suggestions
    New Friend:
  • 114 Answers
Perhaps the performance assistant technology is turned on.
Press the [PERFORMANCE ASSISTANT] button to turn it off.
Posted on Jan 14, 2013
6ya staff
SOURCE:
Michial Gueffroy
  • 1140 Answers
SOURCE: No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
Posted on Apr 28, 2009
Fred Yearian
  • 5603 Answers
SOURCE: I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Posted on Nov 01, 2009
Testimonial: "bur isnt it strange that certain keys have stopped working? ie most the A keys"
Fred Yearian
  • 5603 Answers
SOURCE: Yamaha Electronic Piano- certain notes malfunctioning
Either the first or second closure matrix line for the "A" keys is bad.
This may be a cracked or shorted circuit board.
A bank of diodes is used to prevent sneak electrical path if more than one octave has notes pressed.
First thing is to clean ALL the key contact areas and the conductive rubber pills with 99% isoprophyl alcohol.
This involves dis-assembly of the key area. If you are not competent in electronics, best left to a pro shop.
The keys are scanned in a matrix, two contacts per key and all the individual notes are in common (all the "A;s", "B's"...) And each octave is strobed for the first set of contacts and then for the second set of contacts. an the whole octave is read in parallel.
The reason for two contacts is one closes first and then the other as a key is lowered. The time between these is measured and is the note VELOCITY which for a piano controls the loadness of the note. IF ONE of the two fail, the loudness will vary as yours does.
Posted on Nov 27, 2009
gwcoan
Bill Coan
  • 49 Answers
SOURCE: the keys in the middle
Although the keys have a weighted feel, this is not because of a system involving connection t hammers as in an acoustic piano. This is done mechanically, however, which would indicate a need for cleaning. If you have an authorized Yamaha service center in you area they would need to do the cleaning.
Posted on Oct 31, 2010
Fred Yearian
  • 5603 Answers
SOURCE: I'm using the Yamaha P-85
In playing fast you have to make sure to release the note fully and let the key come up. These keys have TWO contacts that are used in the scheme to measure note velocity. If BOTH contacts don't open, the note will NOT re-fire. The second symptom you have written would be a characteristic if one of the disconnect diodes has shorted. These diodes direct the strobe signals that scan the matrix of key contacts to avoid other octaves responding when multiple keys are depressed including those in other octaves. Servicing of the unit is required. It is unlikely you have the tools to DIY this problem. ONE THING to try is to tip the unit and gently tap it to see if some debris MIGHT have fallen in that may be shorting some of the matrix connections.
Posted on Apr 25, 2011
Hello! I have the Kurzweil Mark Pro TWOi piano. Suddenly some keys make strange sounds through the speakers, like distrortion or noise. The speakers seem to be fine, because the demo songs play perfectly....
Try to re-initialize the unit(factory reset). If the keys are the problem then the rubber key contacts need to be cleaned or replaced. Contact a local service center for help.
Dec 09, 2014 | Music
3 key notes not working and can't write my savings to the banks..
Hi, You can reset your whole keyboard by holding down the top C ( highest key ) whilst turning on.
This is unlikely to clear 3 non working keys. My guess is that the contacts under the rubber switches have worn or dust is under the contacts. You could try cleaning first under the rubber contacts if this fails replace the contacts ( 1 per octave ) Part WF212202 contact me if you need more information
Pictures attached may help 0482dd26-e9cb-4b61-b47e-f97d90aa782c.jpg 42e5c956-fedc-40b9-ae04-8bf3e98b22a2.jpg
Mar 28, 2014 | Yamaha DGX-640 Portable Grand Piano...
Some notes on keyboard leave a horrible piercing static noise when volume is turned three quarters up.
Sounds like feedback from your monitors, the speakers can't be pointing in the direction of the mic.
Sep 09, 2017 | Yamaha Piaggero NP11 61 Key Digital Piano
Yamaha dgx 500 keyboard
Unplug and leave it unplugged for a while and then make sure the plug is nice and secure on both ends and try again
Jul 28, 2013 | Music
G# and A# Ghost Notes!
First try looking in your transpose settings. Refer to your manual to see if any arpeggiation/unnatural chord settings were inadvertently created by you or made by another user. If you believe it is a software problem you can not solve, back up your memory bank, remove your memory card, and hard reset your keyboard. Insert your memory card and check to see if your problem still exists.
If it is a technical problem, it sounds like you may need to get it checked out by an engineer/repairman. Sometimes when a digital keboard's keys collect too much dust/debris they can trigger multiple keys that aren't being pressed. Think about it like a key getting caught on an upright piano and pulling back the hammer next to the one that was played. A digital piano works off of one or several printed circuit boards or PCBs. The printed circuits usually can not short circuit because the wires and circuits sit in fixed positions. If an alien conductive fiber or series of conductive fibers connects a conducter to another, or if there is any humidity inside your piano it may cause circuits to misfire when a circuit is connected in the area. This could explain why notes you are not playing are being activated in the area in which you are playing.
If you are in a humid area and you suspect that this may be the cause you can attempt to draw out the humidity before getting a an expensive diagnostic done. Find a box large enough to house your keyboard. [If it is on a stand take it off and] place it inside the box. Cover the keyboard with plastic wrap (so as to prevent any foreign objects from getting into the instrument) and very carefully surround the piano with white rice. Remove the plastic wrap, close the box and leave it alone for a few days. The rice draws out any moisture from the electronic components. Very carefully (again so as to avoid getting any rice inside it) remove the keyboard from the box; remove any dust from the body, face, keys, and other components. Try your keyboard now. If humidity/moisture on the PCBs was the problem it should be solved. If not it is time to take your piano for a tune-up.
Hope this helps!
Jul 12, 2013 | Yamaha Music
Our Yamaha YDP223 has an issue with the damper pedal. When it is depressed, the notes (F#, G) in the upper ranges make a high pitched, annoying sound as the note dies away. We were dealing with this sound...
All sound is generated digitally and the pedal doesn't modify the sound, it just sustains the generator. This is a strange problem and best suggestion iis to find another unit and compare... it may be a characteristic of the design. There isn't anything that you can do to change this. It could be there is a bad ground inside the unit or the digital data is corrupt in the processor. The fact that it is on a particular set of notes is strange...I just checked on my Yamaha piano that is essentially the same electronics and I notice that on one octave above the middle when one strikes F# and G they "ring out". Now this MIGHT be due to the characteristics of the speakers. Those particular notes seem to clash more. I don't have other speakers on mine and unfortunately you did not mention what brand model you have attached. Consumer grade speakers like fancy stereo speakers do NOT do well on these instruments. One has touse pro grade speakers AND use proper interconnecting cables. The speakers, powered type, must be powered from the SAME receptacle as the piano to avoid ground loops.
Feb 20, 2011 | Yamaha YDP223 Digital Piano
Yamaha P-120 Piano: Graded Hammer (NOT key) dysfunction?
My opinion is you should take the instrument to a yamaha authorized service center.. It's doubtful this will be user serviceable, particularly if the problem isn't on all the keys, and the service center will have access to the parts needed as well as more information from Yamaha than they will share with an end user.
Mar 15, 2017 | Yamaha Music
Apr 20, 2009 | Yamaha Music
Yamaha DGX630 - Digital Piano Logo
432 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
