Sigma 70-300 Macro Motorised Lens for Nikon has stopped autofocus
I have recently purchased a Sigma 70-300mm lens for my Nikon D60 for bird photography and it has been problem free for a couple of weeks. However, recently, it has been malfunctioning when I have tried to focus using autofocus. It makes small clicking noises as if it is stuck and after about 5 or 6 times of pressing down the shutter button half way, it will not focus anymore and it is like the lens shuts down. However, when I autofocus at 70mm, the focusing is fine and the camera makes the normal focusing noise that it should.
I tried autofocus with my 18-55mm Nikkor VR kit lens at 55mm and the focusing is fine. I think I have come to the solution that the focusing gets worse as I zoom in more.
Could someone please help me and tell me what the problem is and if it can be fixed.
Assuming the lens has a Nikon mount, then it will fit and work on the D60. Sigma makes lenses for a variety of cameras; a lens with a Canon mount, for example, will not fit onto a Nikon camera. However, the 70-210 is a rather old lens. Unless it specifies "HSM" it will not autofocus on the D60. The D60 does not have an autofocus motor, relying on the lens to have one. Nikon calls such lenses "AF-S" while Sigma designates theirs "HSM".
Sigma make this lens with different mountings (i.e. Canon, Nikon, Sony/Minolta, Pentax and Sigma). So, if you get this lens with the Canon mounting - yes it'll work with your D60. Any other mounting will not fit on your camera. Hope that helps
Unfortunately, you don't. The D3000 does not have an autofocus motor; it relies on the the lens having one. This particular Sigma lens, unlike its Nikon equivalent, does not have a motor.
Nikon calls their lenses with an autofocus motor AF-S. Sigma calls theirs HSM.
That lens is not an AFS type lens. The D40x camera only uses AFS compatible lenses. You could still mount and use it in M, but it will never give you autofocus or TTL flash.
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor: 1) AF-S, AF-I: All functions supported; 2) Other Type G or D AF Nikkor: All functions supported except autofocus 3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus 4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II 5)
Non-CPU: Can be used in mode M, but exposure meter does not function;
electronic range finder can be used if maximum aperture is f/5.6 or
faster 6) IX Nikkor lenses cannot be used *â¹ Excluding lenses for F3AF
