My camera shuts down immediatly after itt is turned on. What can I do to prevent this from happening?
my camera does the same thing and it is charged what do I do?
There are heaters located inside the door frame, to prevent your doors from freezing shut, and also to prevent condensation on the outside of the appliance. It sounds to me as though that is where your problem is... Hope this helps
Were you at the beach? If so, it more likely started when a single grain of sand clung to the side of the camera's lens barrel while it was being closed.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
have the same problem and it is charged what can I do
