Question about Canon EF 70-200mm f/2.8L IS USM Autofocus Lens
I want a nature camera
I want to buy good camera for nature photo's can someone advice me what to buy? i checked out the canon EOS 5D and i'm convinced with the little knowledge i've got. but since im going for a expencive camera i want to buy the best. i'm new to this feild but cant afford to spend on a basic featured camera and then go for a profesional one. i think the above mentioned camera with a zoom of 400mm would meet my requiermnt. What is your openion?
  • Anonymous May 11, 2010
    Can I just add that is one of the most fully featured answers I have ever seen. You fully deserve a FixYa! for that!
    Absolutely agree that the glass is far more important than the camera.
    Scholar:
  • 58 Answers
First, to answer your lens question, 400mm is unlikely to be adequate. On a digital camera this is going to give only 6x magnification. Some nature subjects will require much more than that.
Also, do not need a fully featured 'pro' camera. These have features which you may not want. Look at lenses first, and let that dictate the camera.
It rather depends on your intended subject matter, but in general for nature photography (I presume you are thinking of vertebrate animals, rather than plants or insects.) you require very long focal length lenses. This is because wild animals are very difficult to approach, and many are comparatively small as well. As an example, you may only be able to get within 30ft of a heron however well you are hidden, and for a bird that size at that distance a 400mm lens will just be big enough. Just.
As a rule you want to fill the frame. So to work out what focal length you need you need to work out the size of the image in the camera. This is not difficult to work out, as the magnification is only the ratio of the subject to lens distance to the (Thoeretical) film/sensor to lens distance. (Most long lenses are physically shorter than their theoretical focal length. That's the true origin of the word 'telephoto', the lens is optically 'telescoped' into a shorter package.)
In reality this varies a little as the lens moves in and out to focus it, but in practice you just use the focal length of the lens. So for out Heron which is about 10,000mm away with a 400mm lens the magnification is 400/10,000 = 4/100 =.04. A heron is about .5m tall (18inches roughly), and 500mm x 0.05 = 20mm. The hieght of a digital sensor is about 16mm, so that's full height, but a heron is a tall bird, so portrait mode might be better, and that will be closer to 24mm.
So in our example, a 400mm lens will do but only for an animal half a meter in size, if you can get thirty feet away. And that's pushing your luck. (The nearest I ever got to a heron without sitting all day in a hide hoping for it to show was twice that distance!)
Most subjects will be smaller, or further away. Getting within 150ft of a deer in clear view is quite a challenge even for an expert stalker. At 1.5m tall with a 400mm lens, the image will be 12mm high. If the subject is a grizzly bear, then I doubt you would want to be that close.
Of course if you are wanting to photograph smaller animals, then the problem is compounded. Especially if they are easily spooked.
In essence you want as long a lens as you can manage, so you can photograph from a comfortable (for the amimal) and safe (grizzly bear) distance. However, as in many instances you won't be able to control that, and the range of animals you want to photograph will vary in size, you really want either more than one lens, or a really good zoom.
Really good zooms of long focal length are very expensive, so two lenses might be a better option, or a long lens with a factory matched multiplier would be almost as good. (Zoom lenses cannot perform at optimum over all the focal lengths available, so really good ones are difficult to design and make.)
So you first need to decide what focal lengths you need.
Then you have to consider camera shake. As a rule of thumb you need an absolute minumum shutter speed of 1/(focal length in mm) for hand-held shots. As you will be using long lenses, with small apertures, you won't be able to take shots hand held.
One (partial) solution is to use an image stabilized or shake reduced system.
Image stabilization is built into the lens, and works by moving optical elements to compensate for vibrations. This makes the lenses much more expensive, and will eat batteries. This has the advantage that it is always optimal for the lens.
Shake reduction moves the sensor in the camera, to achieve the same effect. It makes the camera a little more expensive, but the lenses are a lot cheaper, and that's where most of your money will go!
(Note, that digital image shake compensation is not the same thing, and reduces the image sharpness.)
Of course the traditional solution is a really sturdy tripod. Most tripods are simply not up to the job, so you need to check out as many reviews as you can. But be aware a really good tripod will not be cheap.
The camera mount must be really rigid if the camera is not to move during exposure (A camera with a mirror-up function can help. The mirror is the Major source of vibration in a camera, this allows the mirror to flip well before the shutter fires allowing time for vibration to die away.) and the tripod itself must not flex or twist.
A tripod with the means of suspending a weight underneath is useful, extra weight will make sure the tripod feet are firmly placed and help pre-stress the tripod so any residual 'slack' is taken up. (A simple hook that you can hang a kit-bag on will suffice!)
A good tripod and head could cost £200 or more alone!
As for selecting the lenses....
Canon do some very long focal length lenses but they are also very expensive (£2000+) These include a zoom with image stabilization, and a dedicated multiplier to double the range. A good used example will cost over £1000.
However, you should be aware that Canon are generally quite expensive, and other manufacturers produce similar systems, at various prices. I would look at Nikon, and Pentax, these brands are still well regarded.
Posted on Jan 23, 2009
    Habit-Forming:
    New Friend:
  • 87 Answers
In my opinion Nikon D850. With its massive 45.7-megapixel resolution and outstanding dynamic range, the full-frame D850 is the best option for nature photography. For more detail please visit: http://www.studiopepphotography.com/pre-wedding.html
Posted on Oct 11, 2019
    New Friend:
    Problem Solver:
  • 9 Answers
Get a Canon T2i... You can check out more detailed review for T2i... http://hubpages.com/hub/Canon-EOS-Rebel-T2i-18-MP-CMOS-APS-C-Digital-SLR-Camera
Posted on Jan 25, 2011
    New Friend:
  • 9 Answers
I would suggest to buy Canon EOS 7D 18 MP CMOS Digital SLR Camera with 3-inch LCD and 28-135mm f/3.5-5.6 IS USM Standard Zoom Lens
  • 18.0-megapixel CMOS Sensor and Dual DIGIC 4 Image Processors for high image quality and speed
  • Kit includes 28-135mm f/3.5-5.6 IS USM standard zoom lens
  • Advanced HD movie mode with manual exposure control and selectable frame rates
  • Intelligent Viewfinder with 100 percent field of view; 19-point, all cross-type AF system equipped with dual diagonal cross-type sensors
  • http://hubpages.com/hub/Canon-EOS-7D-18-MP-CMOS-Digital-SLR-Camera
    New Friend:
  • 8 Answers
You should definately get Canon EOS 5D Mark II 21.1MP Full Frame CMOS Digital SLR Camera with EF 24-105mm f/4 L IS USM Lens.Compact, lightweight with environmental protection, EOS 5D successor boasts a newly-designed Canon CMOS sensor, with ISO sensitivity up to 25,600 for shooting in near dark conditions. The new DIGIC 4 processor combines with the improved CMOS sensor to deliver medium format territory image quality at 3.9 frames per second, for up to 310 frames. Triggered from Live View Mode, HD video capture allows users to shoot uninterrupted at full 1080 resolution at 30fps -- for amazing quality footage with outstanding levels of detail and realism. The integration of HD movie capability into a high-end 21.1-megapixel camera opens a multitude of new possibilities for photojournalists and news photographers. With its full frame CMOS sensor and outstanding ISO performance, the EOS 5D Mark II will appeal to any photographer in search of the finest camera equipment available -- from studio and wedding to nature and travel photographers. http://hubpages.com/hub/Canon-EOS-5D-Mark-II-211MP-Full-Frame-CMOS-Digital-SLR-Camera
  • 20 Answers
Hi, I have got an Canon 5D and it is superb. The photos are really clear. It has an automatic flash for the dark!!!!
Posted on Jan 25, 2010
6ya staff
SOURCE:
Why are no photos being displayed on screen after shooting?
PDF]PDF QuickGuide to EOS Live View Features
https://www.learn.usa.canon.com/.../CDLC_EOSLiveView_Q...
Canon Inc.Canon EOS cameras when used in their Live View mode. ... directly onto the sensor, which in turn displays the image ... EOS 40D, 5D Mark II, EOS-1D Mark III, EOS-1Ds Mark III, ... Mark III do not offer movie options. ... to produce a fixed screenbrightness, or Exposure .... settings for the following camera menu options:.
Canon Knowledge Center - Changing the AF Mode to Use ...
https://support.usa.canon.com/kb/index?page=content&id=ART134415
Nov 4, 2015 - ID : 8201360200 _ EN _ 1. Solution ... While the Live View image isdisplayed, you can press the < AF?????????DRIVE &gt; button to select the AF mode on the setting screen displayed. 9. ... If focus is not achieved, the AF point will turn orange. .... Shooting movies with the default settings (EOS 5D Mark III)
Dec 25, 2015 | Canon EOS-1D Mark III Body Only Digital...
How to fix canon 5D mark 2 error #30?
On the 5D error code 30 appears to be shutter related and general advice is to get a professional repair or send it back to Canon.
Aug 04, 2014 | Canon EOS 5D Mark II Digital Camera with...
Eos 5D lcd screen stays black when power is turned on. It will show menu and review photos taken but otherwise remains black so it will not show what is in front of the lens.
Unfortunately the 5D (original) doesn't have live-view - which allows you to see the picture before you take it. It doesn't have video either but I guess you already knew that.
Mar 17, 2014 | Canon EOS-5D Digital Camera
Error 01 in canon eos 5d
Err 01: Lens to body communication error
1.The camera to lens communication is somehow being interfered with could be a problem within the lens itself, possibly the camera body, or something as simple as a smudged fingerprint on the lens mount contacts,
2. Check the lens and the contacts
3. Also check below link if you need a canon eos 5d service manual
http://goo.gl/1rXwuc
thanks
Apr 26, 2012 | Canon EOS 40D Digital Camera
What are lenses that are compatible with the canon eos 5d mark ii
You can use Canon EF lenses. Be careful not to use EF-S lenses, as they cast a smaller image circle for cropped-sensor cameras, not big enough for full-frame cameras.There are other third-party manufacturers that make lenses with Canon EF mounts, such as Sigma and Tamron. Each manufacturer has their own designation for cropped-sensor lenses, so you'll have to check the specifications for each of them.
Apr 22, 2012 | Canon EOS 5D Mark II Digital Camera
I am using a canon 5D with gbtimelapse software and need to download canon drivers and software. what drivers do i need?
Visit this link to download drivers & software for Canon EOS-5D , Select Operating System and start downloading it.
Good Luck...don't forget to rate the solution.
Feb 28, 2010 | Canon EOS-5D Digital Camera
Try and fit Canon EFS Lens to EOS 5D Body
As far as I know, you should use L series Lens to fit Full Frame Canon Camera (5D & 1D).
That would be no adapter, but please correct me if I'm wrong.
Jan 13, 2010 | Canon EOS-5D Digital Camera
SHUTTER JAMMED SHUT ON CANON EOS 5D
It would seem this problem has frustrated other users, read this thread on photo.net
Oct 22, 2007 | Canon EOS-5D Digital Camera
Canon EF 70-200mm f/2.8L IS USM Autofocus Lens Logo
396 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
