The screen on the left bottom corned broke,can see much of the screen
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
SOURCE: Sony HP1080p Bravia 46 in Cracked Plasma Screen
Typically the replacement panel is too expensive to replace. If you can update this with the model number of the set, I will post the part number and cost so you can make your own decision.
Thanks,
Dan
SOURCE: Sony Bravia XBR4 52inch LCD cracked
It can be replaced, but it is probably going to cost you more then the cost of a new TV to do it.
Read the tech tip I wrote on this very subject.
http://www.fixya.com/support/r3831376-when_cracked_lcd_led_or_plasma_tv
