If your Viking oven VESO107CSS will not heat and the cleaning light is flashing, it's possible that the oven control board is experiencing a fault or malfunction. Here are some steps you can take to troubleshoot the issue:
- Turn off the power to the oven: Before attempting any repairs or troubleshooting, make sure the power to the oven is turned off at the circuit breaker.
- Check the door lock: If the oven door is not properly locked, the cleaning cycle will not start. Check to make sure the door is securely locked.
- Check the oven control board: The control board may be experiencing a fault or malfunction. Try resetting the control board by turning off the power to the oven for a few minutes, and then turning it back on. If this does not work, the control board may need to be replaced.
- Check the thermal fuse: The thermal fuse is a safety device that protects the oven from overheating. If the fuse is blown, the oven will not heat. Use a multimeter to check the continuity of the fuse, and replace it if necessary.
- Check the heating element: If the heating element is damaged or burnt out, the oven will not heat. Use a multimeter to check the continuity of the element, and replace it if necessary.
If none of these steps solve the issue, it's recommended to contact a qualified technician or the manufacturer's customer support for further assistance.
