Mad dog kit? Bird dog kit? Some kinda dog or somthin'?
Your model number will be located somewhere around your tub opening under the lid. The parts you are looking for are called "agitator dogs" (yes, there is such a thing). There are four of them located under the agitator cap that help grip the agitator shaft when turning. This causes the agitator to crank in one direction during the wash cycle. The part number for the entire repair kit is 2744 and costs $16.80. This includes all the washers and bushings as well as the dogs. If you just want to purchase the dogs, the part number is 3109 and costs $5.20. For a little more, the entire kit would be a better recommendation. You can get everything you need at repairclinic.com. If you cannot locate your model number, type in the brand name of your washer (i.e., Whirlpool Stylemaster Washer) in the "Search" window and you will find what you need. These parts are the same identical parts that your major appliance service companies use, but cost much less (I should know, I used to work for one of them). Let me know if you decide to repair on your own and I can give you follow-up advice on how to take the agitator apart and replace the parts you need.
