Mitsubishi LT-46144 46 in. LCD HDTV Logo
John Banias Posted on Jan 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Misubishi LT-46149 solid red light
After resetting the TV it goes to a solid red light
Anonymous
Level 3:
  • Master 1,238 Answers
  • Posted on Jan 14, 2013
Anonymous
Master
Level 3:
Answers
1238
Questions
0
Helped
329607
Points
3603
Your TV is on stand by., you possibly have power supply board problem or main board.. you have to call a service
3 Related Answers
Anonymous
  • Posted on Dec 09, 2008
SOURCE: Mitsubishi LT-46149 no video only sound
Having he TV replaced under warranty.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Dec 15, 2010
SOURCE: 2 year old Mitsubishi LT-46149 46" LCD Flat Panel
Does it come and go? I would try reseting the ribbon cables between the LCD panel and the T-CON board first.
The Flexible Printed Circuit BoardS (FPCB) are ultrasonic welded to the LCD TFT panel, they are not SOLDERED on! The connections do get bad due to very delicate nature of how the LCD panels are made. You can also try squeezing the around the top area of the screen where the lines are to see if the lines go away.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
electrotech1
Veril Gillette
  • 1126 Answers
  • Posted on Feb 06, 2011
SOURCE: On a mitsubishi tv (LT-46149)
It is possible that you have a bad power supply, or the TV has been hit by a small power surge and if you unplug the set from the wall for 40Min., it will rest back to normal.
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
On a mitsubishi tv (LT-46149) the manual intructs us to wait exactly one minute for the LED green light to stop flashing and then its alright to turn on the tv, the problem is that the light wont stop...
1helpful
Mitsubishi LT- 46149 LCD TV turns on with pic then pic blacks
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Status light stays red no tv no power light
TV requires service. but try to reset it by pressing system reset
I bought floor model and need a manual
There might be some similarities in the manuals with these models (since they are the same brand of LCDs).
http://www.retrevo.com/samples/Mitsubishi-LCD-TV-manuals.html
Misubishi LT-46244. On the left side of screen there is a fine black line that goes from top of TV to bottom of TV. It almost looks like a string of emitters are off.
That is a good guess. You have a row of lcd's that are bad. The only fix for this is to replace the lcd panel. This is very expensive. You should just buy a new tv.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
