Only got it yesterday it done 1 wssh ok then bangs freezes and red light flashes on and of
If this is a new machine then you must contact the dealer immediately as it is due to damage in transit or alignment issues with the drum while it was moved. Possible the drum or suspension is out of sync and must be replaced, also if there is damage on the chassis then it must be claimed on warranty.
SOURCE: Boom and Bang Washing Machine
Bed sheets or comforters will often get out of balance in the spin cycle or during the rinse cycle. Throw some towels in there next time at least 5 big ones. They are engineered to take a little of this banging, it should only happen once in a while.
SOURCE: indesit WI 121 washing machine
If this is a front loader it could be the up/down motion causing machine to vibrate against the floor. You can pick up some cushion pads for front load washer and dryers at the dealers to go under the four corners of the machines.
SOURCE: very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
SOURCE: loud banging noise during washing cycle. Sounds
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
